Question about Schlage Locks & Locksmithing
Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
Schlage FE365v keyless entry lock.... Cannot find my user manual, and I cannot remember my 6 digit programming code. How can I restore the lock and set a new code?
  • Heather Jan 17, 2013
    I have a keyless entry that no longer opens with the code. I changed the batteries and when I enter the code the light flashes green but won't open. Any solution?
Look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
If you take it apart it is on the inside usually.
Posted on Jul 29, 2009
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
Lost 6-digit programming code and need to restore lock to put in another
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Jan 13, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
How do I set the key pad to my on code on my schlage electronic keyless lock
This link will give you instructions for various models of Schlage locks, including the BE 365:
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I am looking for the manual that would tell me how to reset the codes in my keylsee entry locks
Dec 28, 2010 | Schlage Locks & Locksmithing
I have a 4 digit schlage keyless lock and want to reprogram it
There's a video for reprogramming it.
Dec 20, 2010 | Schlage Locks & Locksmithing
I have the same kind of problem. I have the programming code, but when I enter it, after entering the 4 th digit the lock blinks an error thinking I entered an incorrect user code?? So I think I might have...
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Aug 30, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Need info to change code
Here's a link to the Schlage web site with pdf's and videos showing how to operate and program your lockset.
Just select which info you need from the list on the page.
http://consumer.schlage.com/customerservice/FE575_install_inst.asp
Hope you find this Very Helpful - Best regards!
Aug 20, 2009 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Locks & Locksmithing Logo
9,311 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
