Question about Echo Garden
Will not power up
I have an echo model 2100 power blower 7 years old. It has been excellent up to now. It will not power up. It feels as though it is starved for fuel but idles great and runs fine only at low speeds. Feels as though it has choke on when trying to increase power. Have cleaned spark screen, new plug, new fuel filter, and new air filter. Am I looking at carberator $$$$$ problems and if so is it worth getting fixed? Thank you very much.
  • 398 Answers
Have you tried to adjust the carb? screw all screws all the way in , then back out 1-1/2 turns then try to start it and tell me what happpens in detail, thanks.
Posted on May 17, 2009
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
May 15, 2014 | Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas...
No fuel in primer bulb on my echo PB 2100 blower
The primer bulb pulls fuel from the carb into the bulb and dumps back to the tank, so either the tubes are not connected too the correct conections on the carb, or there is bno fuel getting to the carb from the tank ( fuel filter ) or if the primer is on the carb itself there in a red one way valve under the bulb which maybe faulty.
Jun 16, 2012 | Echo Pb-2100 Pb 2100 Leaf Blower Inner Fan...
NoHow to change Primer
Go to Echos' web site and find your model blower, then go to the schematic for the carburetor and use that for the road map to replace the primer.
Dec 09, 2011 | ECHO, Inc. PB-251C Handheld Blower
I have a 500VL saw, about 30 years old that was serviced once about 15 years ago. It starts, but then stops, as though it is starved for fuel.
a good bet your carb needs to be cleaned especially if it has been sitting for any length of time.
Sep 02, 2011 | Echo Garden
What kind of fuel do you put into an Echo PB201 Leaf Blower?
The blower is a 2 cycle, so you run an oil and gas mixture. Here is the link for the owners manual.
http://www.echotool.ru/files/50_17_21-21G-00.PDF
Apr 08, 2011 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
What 2 stroke fuel ratio do i use for the es 2400 leaf blower
50 to 1 don't use outboard 2 stroke oil. Use good oil echo, still, Husq ect.
Sep 27, 2010 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
What type of oil do I need to mix with the gas for the Echo PB 2100?  Also, what ratio?
Misplace your Manual? Want to view a Safety Video? Look up a Part for your ECHO Equipment? Do It All Right Here
  • www.echo-usa.com/documentation.asp?Model=PB-2100&lang=E
  • Echo recommends 89 octane fuel and 50:1 mix to one gallon gas for your pb2100
  • go to this site and find fuel and read about it if you would like
  • i use 40:1 in everything i have and have had no problems
  • The oil you buy make sure it is for 2 cycle engines and not outboard motors
  • 50:1 =2.6oz to i gallon gas
  • 40:1 =3.2 oz to i gallon gas
Jun 07, 2009 | ECHO, Inc. PB-251C Handheld Blower
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo polesaw won't pick up gas, took carb apart still no run.
Vacuum test the fuel line and check the fuel filter.
The fuel line could be cracked.
Mar 25, 2009 | ECHO, Inc. PB-251C Handheld Blower
Open Questions:
Garden Logo
266 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
