Question about Vacuums
The carpet cleaning portion of the vacuum sucks debris up poorly, and during the whole time I have it on carpet, the hose continues to have strong suction. The vacuum also spits out what its vacuumed up.
  • nannerk0413 May 16, 2009
    Thank you for such a great and detailed solution for me! nannerk
  • 3,741 Answers
The screws along the base of the vacuum must be removed . The vacuum cleaner cover must then be removed exposing the suctioning hose syphoning the debris from brush roll area. Pull the hose from the brush roll area letting it hang freely. Remove the back side removeable hose from its base and force a straigth piece of pipe through the hose to force out the clog through the free opening. ----------------- alsocheck brush roll rotates. also check air path away from brush roll - this is the most likely area for a blockage. to do this you will have to take the base off and remove the brush roll. The main purpose of a vacuum cleaner is to agitate fibers in a carpet and **** up any debris. There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 16, 2009
  • charlymonty May 16, 2009
    thank you for keeping updated.
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
The suction on my bissle 93Z6 isn't working. I can turn the vacuum cleaner on but only if the brush is engaged? Any helpful suggestions to troubleshooting the problem?
I am not sure I understand your question. If the problem is that the vacuum won't run without the carpet head, that is beyond my expertise. If the vacuum is on and there is no suction, there are only three possibilities: 1. There is a plug somewhere between the pick up point and the fan. 2. There is a hole somewhere between the pick up point and the fan (an air leak reduces the vacuum) or 3. The motor is running but the fan is not turning or has been damaged badly.
My son's Bissel lost suction when used to clean carpet, but was fine when doing hard floors. The plug was in the line between the brush and the point where the hose could be removed and connected to a wand to do hard floors. It is difficult to see a plug in this section of the line (it is hidden inside the head). I was able to use a stiff wire (with the vacuum off) to dislodge the plug. (I inserted the wire, poked and prodded the plug., turned the vacuum on and checked to see if it would suck out the plug and repeated until the plug finally cleared.)
My daughter's Bissel lost suction when something (I have no idea what!) abraded the line (short section of ribbed hose) close to the brush so that there was a major air leak. Being cheap, I disassembled it enough that I could wrap that section with electrician's vinyl tape to seal the leak.
I haven't had a vacuum where the fan became disconnected from the motor, but I have had fan destroyed. I had a leaf blower that could also be used as a vacuum. In vacuum mode everything that was sucked up passed through the fan. Unfortunately, it was a strong vacuum and would pick up small rocks. When a fan has lost most of its blades sucking rocks, it stops sucking anything! Most vacuum cleaners are designed so that debris can't get sucked into the fan, so this is the last thing to check. It requires significant disassembly to be able to see the fan and can be dangerous to turn on to observe its operation once exposed.
Jan 29, 2015 | Vacuums
Why is suction too strong
Hi there, it's Jack at Dyson.
DC33 is a powerful upright vacuum, with strong suction to clean carpets and hard floors effectively. However I'm surprised to hear you're finding your machine hard to use on this particular carpet type.
I would encourage you to contact us directly, as in order to help we would need to take some further information about the carpeting, and how you're using your DC33.
When you have your vacuum to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 04, 2014 | Dyson DC33 Bagged Upright Vacuum
I am having problems with the hose, it is collapsing when I try to use it to sweep furniture and baseboards. I have checked for any blockage and cleaned all the filters the bar for the carpet works fine...
Sorry to hear you're having difficulties with your Dyson cleaner. It's normal to experience some resistance from the hose during use due to the cleaner's very powerful suction.
However, if you're concerned that the resistance feels unusually strong, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your cleaner. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Aug 16, 2011 | Dyson Vacuums
Poor suction...continued
Wish I had it in my shop, it is hard to figure your problem. I do know that you must have something out of place and you may have to take it apart to find it. You may feel some suction there at the top of the clear nozzle, but maybe it isn't strong enough to pull anything up, but you may have a problem witrh it not seating all of the way on both sides, and you ,maynot feel much there anyways. Check at the bottom where the tank sits. is the seal ok. With the tank off, is there alot of suction at the filter screen? If there is, then the problem wouldn't be inside. Is the hose door on the back closed tightly? How old is this unit, if less then a year, then it is under warranty. There is an automatic shutoff for suction when it senses that the tank is full, maybe the problem is there. I believe it is the float inside the tank.
May 01, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Nov 23, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
189 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
