Question about Kenmore 54701 Dehumidifier
I was told that putting my de himidifier against to wall can cause damage to wall, if the unit touches to wall from the back of the unit. Can you please tell me the minimum distance the the dehumidifier can be from the wall?
    Problem Solver:
  • 9 Answers
If it vents or blows air out the top you can put it against a wall. If it blows air out the back it will heat the wall and also impede the airflow through it and make it work less efficient. I would check with the manufacturers owners manual or their website.
Posted on May 17, 2009
Bought the Frigidaire 6000 BTU Window Room Air Conditioner LRA067AT7 6 months ago and it worked fine until last week, It will not turn on although plugged in and the wall outlet is good. Is there an auto...
Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
    5)Or instead of washing, you may vacuum the filter clean.
    Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
    The power supply cord contains a current device that senses damage to the power cord. To test
    your power supply cord do the following:
      1)Plug in your Air Conditioner.
      2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
      3)Press the RESET button. Again you will notice a click as the button engages.
      4)The power supply cord is now supplying electricity to the unit. 4)
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
Jul 09, 2014 | Frigidaire 6000 BTU Window Room Air...
My GE basement dehumidifier is overheating. The bucket still collects water and the fan works, but the unit is putting out alot of heat. My dad is visiting and has taken the whole thing apart. Any...
Yes, the first suggestion is I hope your dad can get it back together without any parts left over (LOL). Over heating is generally caused by an clogged or dirty air intake filter. Simply removing it and vacuuming it or if it's really dirty, washing it in warm water and mild dish washing liquid will clean it. Rinse it thoroughly, shake off excess water and allow to dry completely. Never operate the unit without the filter in place. Doing so, can damage the unit.
Getting back to the heat for a moment and where you're using your dehumidifier. Dehumidifiers do generate heat, it's not abnormal. Operating it in a basement can cause it to over heat. This happens because the air temperature at floor level is colder than at shoulder level. Dehumidifiers struggle in temperatures below 65 degrees F (unless you have a Low temp unit, designed for basement applications). Raising the unit up off the floor, on to a sturdy table, counter top, etc, that an handle the weight of the unit, plus a full bucket of water, will generally resolve the problem.
Actually, a basement application , higher is better.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | GE AHG40LJ Dehumidifier
There is no water accumolating in the de-himidifier bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 31, 2011 | Daewoo DHC-400 Dehumidifier
No power at all. pluged into wall.i push bucket switch and try to start up,nothing.no power
To troubleshoot the problem: First start with the wall outlet. Is there still power to it? If not a circuit breaker in your homes breaker panel may have tripped. Is there a lose wire connection in the outlet or is the outlet damaged inside? If all of these things check out OK, try plugging the unit into another outlet that's on a different circuit.
Other causes:
The bucket is full. Unit shouts off completely when this occurs.
The bucket is not installed properly. Remve bucket and reinstall it "squarely" from top to bottom
into the bucket holder.
If the ambient room temperature is 112 degrees F or lower than 32 degrees F, the unit will shout down to protect the compressor. Wait 3 minutes and then restart the unit.
If all of the above troubleshooting fails to resolve the problem. Call Haier Customer Service
1-877-337-3639.
I hope this has helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier HDN655E Dehumidifier
How do I change the air filter
To remove the filter:
1. Turn the unit OFF & Unplug it from the wall receptacle.
2. Remove the water collection bucket and set aside.
3. Just inside the water collection bucket holder at the top, you should see the a plastic frame
behind the front louvers of the unit. It may have a plastic pull tab. That's the filter.
4. Pull it straight down and then remove it from the unit.
5. Wash it in warm water and mild dish washing liquid. Rinse thoroughly and dry thoroughly before
reinstalling it. The filter should be cleaned regularly. NEVER operate the unit without the filter in
place. As this can cause damage to the unit.
Hope this helped you. Please let me know. Thanks.
Jul 08, 2011 | DeLonghi DE50P Dehumidifier
Touch control for humidity setting only goes up, cannot lower setting, is touch pad defective and can it be replaced or not worth it anymore
Yes, the touch pad may defective. But, before you try to replace it, let's try something else first.
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set the humidity extraction level where you want it. Hopefully, that 15 minute time out allowed the unit to reset itself and revert back to the original factory settings.
If it didn't you can order replacement parts directly from Haier 877-337-3639 or locate a service center near you.
Hope this helped to solve the problem. Please let me know. Thanks.
Jun 03, 2011 | LG LHD45EL Dehumidifier
E3 ERROR
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Jul 22, 2010 | DeLonghi DE500P Dehumidifier
Most of the time our fan runs very loud, vibrating against something?, fan wrecked? it just started doing it, it is about 4 years old
did you try to open the unit, unplug it of cause..something may have entered the unit fan.
you may have to physically remove said object.
Aug 22, 2009 | Dehumidifiers
Same Problems as Everyone Else
I have a Danby DDR 458EE dehumidifer that I purchased May 27, 2008.
Used it for the summer and stored it until May this year. At the end of July of this year it started not working. It freezes up. Called Danby, they told me it was out of warrenty and to take to a repair shop. Problem being it was leaking freon so have it recharged. Called the repair shop and they explained that it is a closed system and if it is leaking Freon, they can not recharge it until the leak is found and repaired. It's against the law to discharge freon in to the atmosphere. Stated cost to repair it would be greater then buying a new one. Called Danby back and explained what repair person said. Still waiting to see if they will give me a pro-rated refund.
Jun 13, 2009 | Danby DDR6588EE Dehumidifier
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Kenmore 54701 Dehumidifier Logo
64 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
