Question about Microsoft Windows 98 Second Edition for PC
Missing apcmain exe.
It says am missing the acpmainrxe. linking to missing export kernel 32 dll also says am missing dll file msvep80 how do i fix this please
  • 28 Answers
If you have the install disk, try and boot from the disk and reinstall. To change boot order, press the key to enter bios. (different on different pc's) Common ones are f8, and delete. If you have valuable data on the Computer you dont want to lose, then use a recovery disk. (BartPe is a good one. Just google it.)
Posted on May 23, 2009
Msvcr80 dll
Are you facing the MSVCR80.dll-Missing problem? If Yes! Then follow these steps to fix it.
- Reinstall Microsoft Office
- Resolve Corrupted MSVCR80.dll Related Registry Entries
- Restore Deleted MSVCR80.dll File
- Check the Status of System Files
- Restore the System
Source:-
http://www.sorcim.com/knowledgebase/MSVCR80.dll-Missing.html
Jan 27, 2014 | HP LaserJet P2015dn Printer
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
Kernel32.dll can be a problem, so my pc taking too much time to shut down
How to perform kernel32.dll repair, one common methodinvolves acquiring a new version of your kernel32.dll file and installing itright into your registry. This will fix most problems with the file- like ifit's missing or if it's still there but has become corrupted at one point oranother.
Dec 21, 2010 | Computers & Internet
I am running Windows 98 on one of my old computer for the children. When windows starts up I am getting to error messages in starting program: apcmain.exe file is linked to missing export KERNEL32.DLL...
You need to have your operating system repaired. You will need to have your windows 98 operating system disc.
Dos knowledge will be needed to repair this issue.
I hope I was able to shed some light on this issue.
Upon request I can assist in this matter or provide DOS commands.
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help
resolve your issue.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 21, 2010 | Computers & Internet
Missing DLL files
hi,
http://www.fix-all-dll-errors.com/
Just visit this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Apr 08, 2010 | West Wood Studios Command and Conquer...
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
My KRMnl.dll file is missing,how i again restore it in my system files. Every time i start my system,a run error come RUN.DLL. HOW I SAVE SYSTEM FILES FROM VIRUSES.
To stop the error from happening we will have tostop the process by deleting it from running in the Windows RegistryEditor. To run the Registry Editor, go to your Start menu and open Run,type in RegEdit and press enter.
PLEASE NOTE: The Windows Registry is an INTEGRAL part of Windowsitself, so please use caution in editing the CORRECT registry keys. Ifany mistakes are made, it can corrupt your entire system.
Remove the following registry item with RegEdit:
Open the HKEY_LOCAL_MACHINE folder
Open the Software folder
Open the Microsoft folder
Open the Windows folder
Open the Currentversion folder
Click on the Run folder
Click on the WildTangent CDA file (RUNDLL32.exe)
Delete the file by pressing Delete on your keyboard.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
Dll fix
have you complete the installation fully? you need to make sure it complete.. you may want to read below link to have more understanding about dll error...
http://etech.maiila.com/repair-kernel-32-errors-and-fix-dll-file-error-messages
hope this helps...
Nov 05, 2008 | Ahead Software Nero 6.3 Reloaded (60096)...
Blue Screen
Use the following steps to replace the missing files when Windows cannot start.
  1. Turn the computer on and place the first recovery disc into the top drive.
  2. After inserting the disc, turn the computer off, wait about ten seconds, and turn the computer on again.
  3. If an HP Recovery screen displays "Press any key to continue...", press the spacebar.
  4. To continue, read the warning screen and click OK.
  5. Click Advanced Options at the top of the screen.
  6. Click Selective Recovery.
  7. Read the Select Files to Restore window that appears.
  8. Type the name of the file. For example, if the error message is MNYUTIL.DLL is linked to missing export MFC42.DLL, type MFC*.DLL.
  9. Click OK. If there is more than one recovery disc, it may be necessary to insert another disc when prompted.
  10. When therecovery process has finished copying files, remove the disc andrestart the computer. If problems, persist it may be necessary toperform a system restore or a non-destructive recovery.
(Note: Click here for information on ordering the recovery CD/DVD sets)
thx.
Oct 08, 2008 | HP Computers & Internet
Microsoft Windows 98 Second Edition for PC Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
