Question about Samsung SGH-D500 Cellular Phone
Helpind to repair my D500 bluetooth error
My D500 does error when i active the bluetooth.please help me
  • 490 Answers
Plz confm error message or contact service centre.
Posted on Oct 19, 2007
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Samsung sgh-d500, blue tooth and infrared not functioning
on phone go to menu/settengs/ok/scroll down to connectivity/ok/two choices here, bluetooth/infrared/ok/look at your choices here that should get you going? any problems let me know,
Mar 01, 2009 | Samsung SGH-D500 Cellular Phone
Bluetooth freeze
I flashed mine ,now its ok
Nov 25, 2008 | Samsung SGH-D500 Cellular Phone
Samsund d500 mobile
You must try with different Bluetooth devices. I believed your D500 is not compatible with your Bluetooth Headset. Email me to, I will send you a troubleshoot guide
Feb 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth error and infa
your bluetooth inside the phone does not make proper elctrial contact on the board ta it to the service provider to re install the bluetooth device. advice by dogy.
Dec 16, 2007 | Samsung SGH-D500 Cellular Phone
I know that it is not very helpfull to say this,but you are not alone with this fault which appears to be quite common to the D500.I assume that the same notice appears when you attempt to activate IR as this is usually the case. The only suggestion that has been doing the rounds is as follows. Remove the back and look at the chassis and you will see a square IC unit near the battery connectors. Apply heavy but carefull pressure on this and try the Bluetooth again. This is said to have cleared the fault in at least two cases.
Dec 04, 2007 | Samsung SGH-D500 Cellular Phone
Bluetooth fault
There are two places where can be the problem. 1. Bluetooth module is faulty 2. Infrared module is faulty. Mainly there is a problem with bluetooth module. This module needs to be replaced with hot air. It needs to see repair center. But think...Repair will cost you at least 40 pounds. Is it worthy?
Sep 12, 2007 | Samsung SGH-D500 Cellular Phone
Bluetooth and infared
check your imei and bt mac adress.if they are not paired,bt and ir port will not work.other thing that may be wrong is bt module itself,that got damaged after the fall of the phone
Aug 25, 2007 | Samsung SGH-D500 Cellular Phone
you have to rehot or change the bluetooth is near sim card reader with metalic color
Jul 24, 2007 | Samsung SGH-D500 Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
111 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
