Question about Panasonic TH-65XVS30U 65 in. HDTV Plasma Television
I have the Panasonic TH-50PE8U plasma tv and a Dell Latitude laptop. I tried connecting those two together as the tv as a monitor but when i plugged it in and restarted the laptop it would show up on the welcome screen on the laptop but then when the desktop loads it turns black and disappears. I have done the fn+f8 button and the fn+f5 buttons, I have the s-video cord with the 4 pins and the separate audio cords. I dont know what else to do.. Please help!
My girlfriends computer did this a lot. What we did and I don't know if it would work for you was to use the HDMI cord (obviously your laptop has to have an HDMI). The S-Video cord was very tricky to keep it from going black we had to mess with the cord a lot!
Posted on Feb 18, 2010
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
Is th-50pe8u audio out fixed or variable
I do believe those audio outputs are fixed pre amp outputs that connect , for example, to a home theater system.
May 21, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic Viera TH-50PZ800U monitor driver
You don't need a driver. Just connect it to your PC and choose in the TV menu correct input source.
Aug 09, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
Why does the s video output on my dell latitude d600 not work?
You must have the correct drivers installed, and you must enable the output as a second monitor but to do that you must connect to the TV IN first. Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Feb 17, 2010 | Dell Latitude D600 Notebook
Connect Dell Latitude D600 to TV
try holding down the fn button and pressing at the same time the button with a small screen on it will do monitor switching
Aug 06, 2009 | Dell Latitude D600 Notebook
Panasonice TH-50PE8U Red/Purple Line
take a rotary vacumm and make circles on screnn make sure tv on and vacumm, back up slowly making circles that take up the whole tv, repeat this s couple times, it goes away
Jun 22, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
Linking up Plasma,PS3, and Receiver
If your tv and reciever have optical audio (square-ish hole with a red light), that would be the easiest way. Just get an optical audio cable and plug it into the optical out on the tv and into the optical in on the Sony.
Dec 30, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TH-65XVS30U 65 in. HDTV Plasma Television Logo
187 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
