Question about HP Computers & Internet
Blank screen with beeping sound
Black out with beeping sound
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats laptop model? whats kind sounds? how many short beep and long beep (sequence)?
    Problem Solver:
  • 7 Answers
When a computer turns on it performs a POST (Power On Self Test) it check everything to see if everything is Kosher if so then it loads drivers then boots the OS (thanks to the BIOS) but if it come upon an error it immediately halts the POST and gives you a code...if it finds a problem after the drivers load (like the lake of an OS for example) then it would display the error rather that beep it...either way it wants to inform u of the error. based on ur situation the error was found prior to the loading of the drives. i recommend no doing anything and taking it to the geeks at geeksquad or someother PC service place (dont go to the flash attractive PC places however) hopefull the geeks at geeksquad will help you...
Posted on May 16, 2009
  • Derkek
    Derkek May 16, 2009
    ****...typo befor POST lake should be lack
    Sniper:
  • 79 Answers
If its a multi Beep right after you turn it on, its a memory problem (more than likely). Turn it off flip laptop over, remove the panel covering up the memory slots. remove the memory, and reseat them back into the slots. replace cover, and boot the laptop. If that doesn't work, try only one stick at a time and see if it boots without beeping. If that fails, try replacing it with another stick of ram for that laptop.
But it would help if you could elaborate on your PC model and how many beeps?
Hi. I Inherited a DELL Poweredge 1600SC server. When I switch it on, it powers up but the screen remains blank [black without any beeps]?? I remove all the memory and switched it back on again = NO beeps....
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
Aug 01, 2013 | Dell PowerEdge 1600SC Server
MY GT5654 desktop pc.makes a beeping sound when i turn it on.and get a blank screen.what is wrong with it?
you proberly got BAD RAM.kurt if just a upgrade did you get the right RAM.if not a upgrade videocard maybe.infomation is essential to little information.
Apr 11, 2013 | Gateway GT5654 Desktop PC
Inspiron mini 1018 blank screen with light behind, loud beeps, strange smell
I have green screen solution where now it changed to whole black screen with some red line and produce a sound like TV Signal..I don't know everthings about repair my netbook..What should i do?
May 29, 2012 | Dell Inspiron 1018 Notebook
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
Power on screen blank.. fan on
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. You can disassemble or remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion dv6704nr Notebook
When turned on loud beeping sound black screen
i sounds like a graphics problem but try and re seat the memory 1st. disconnect anything connected to the laptop, unplug it and remove the battery. remove the memory module(s) and re seat them. but the battery back in, plug it in and restart it.
Aug 07, 2009 | Computers & Internet
Not starting blank screen and beeping
dear if you hear the beed sound then your RAM memory is not work please reinserted or change the RAM.
this solve easily
Apr 09, 2009 | HP OmniBook XE3 Notebook
Blank screen, led lights on, intermittent beeps
take out the RAM of your laptop, put it again,
also check the display on external monitor through vga port
Oct 20, 2008 | HP Compaq nc6000 Notebook
Computers & Internet Logo
384 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
