Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Computer interface problem
I've used USB plugin accessories before and not had a problem.  Our machine is still USB1, but it takes anything.  For some reason, it isn't even recognizing the Sansa c250 MP3 Player.  Any ideas>
Thanks much.
  • Anonymous Jan 15, 2008
    having probles
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
I have a Canon MX410 inkjet printer that recently stopped working.
looking at the specifications of your printer it uses a usb2 interface.
You may have plugged the usb cable into the usb1 port of your computer or an incorrect port . As you did not mention the make or model number of your computer I cannot be 100 percent certain this is what is wrong.
https://appuals.com/how-to-identify-usb-ports-by-their-symbols/
Jan 29, 2018 | Canon Office Equipment & Supplies
How do I connect a 180e serial cable to my usb computer when Artlink and CPS software specify serial port?
I've not successfully managed this ... trouble-is that although you can get USB-to-serial converters, most computers that only have USB ports do not properly 'recognise' COM ports, which is what your Artlink software expects to talk to. I still use an old PC with a 'proper' 9-pin serial port on the back in order to talk to the old Artista range of machines. One of the drawbacks of a 'throwaway' PC industry that expects the rest of the world to continually update everything in response to new interface standards!
Oct 08, 2011 | Bernina Artista 180
How do I get the saved files from my GoFlex on my new computer
You should be able to just plug it in to USB and read them since the harddrive has aleady been set up and used. The new machine should read it just like it will read a thumb drive you've saved files on. This is one of the big reasons why people like these external drives :) You can take them with you and use on another computer.
May 28, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Forerunner 305 "problem receiving activities"
I've had this problem. First -- and this sounds weird -- use a USB port on the back of your computer. Do NOT use a "secondary" type of USB port, such as an add-on hub, the ports on the front of a desktop machine, ports built into peripherals like a monitor, etc. Apparently, all USB ports are not created equal. Second, make sure you've the freshest Garmin Communicator plugin (which may entail a fresh download/install).
Apr 28, 2011 | Garmin Forerunner 305 GPS Receiver
How to map usb ports USB1, 2, etc.
You don't map the Universal Serial Buss. You just hook all the devices to the connection points (ports). The computer find them by device, MAC address, etc., not by port number. You can hook up to 127 devices to a computer, and the computer will talk to all of them regardless the physical point of connection. That's the reason, you can buy USB hubs with 4 or more connection points that plug into an USB port (how do you map that?).
USB1 - 6 is for you to know how many devices are connected to the computer via USB at a certain time.
So if your printer is configured for USB1, what ever port you plug that printer in, will be USB1.
Oct 02, 2009 | Dell Dimension 2300 PC Desktop
I Need Windows XP Drivers for Sony VAIO VGN-NS10L/S Laptop
Good day!!! I know the link for the VGN series for windows XP drivers you can download the drivers there ( http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/ ) hope this one can solve your problem.Cheers and God Bless.
Jun 23, 2009 | HP LaserJet P2015 Printer
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
Audio drivers needed for my pc. plz help.
Sound card driver for
Realtek AC97 Audio CODECs Driver v4.06 Windows 98SE/ME/2000/XP/2003(x32/x64)
http://www.opendrivers.com/driver/286655/realtek-ac97-audio-codecs-driver-v4.06-windows-98se-me-2000-xp-2003(x32-x64)-free-download.html
Mar 23, 2009 | Computers & Internet
Wi fi
You need a wireless card.
Either an internal solution like this
Or an external solution like this.
Install them, then your desktop is wi fi compatible.
Jul 02, 2008 | Televison & Video
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
