Question about Toshiba Libretto 50CT Notebook
Just bought second hand,cant get it to load past 86%
Help !!! i have no instructions ,the screen is blue and checking for errors is there a help manual on here ?
  • Toshiba Master
  • 5,568 Answers
Have you tried booting into the Safe Mode?
This won't necessarily fix anything but will at least tell you if some of the Windows installation is intact.
When first powering it on, tap the F8 key as soon as anything appears on your screen.
If that doesn't do it, try F5 it varies dependent on Windows version and/or system.
If you can get to the Desktop (it will look awful-icons spread way past the screen limits) and run some initial checks on it such as chkdsk to see if the hard drive is intact.
If you get this far, post again and tell us what happened.
Posted on May 16, 2009
Dell inspiration 1520 doesn't go past Windows Error window. My computer goes past the dell loading screen, then Windows Error. After I pick one (or go into f8 and pick system repair) then the screen goes...
Possible hard drive failure. You may have to reinstall the operating system and if that doesn't work then you have to get a new hard drive. The tech may or may not be able to recover your files from the damaged unit.
May 18, 2014 | Computers & Internet
Wont go past boot menu
your dvd rom or your disc might not working properly. there can be one more problem that you RAM is creating problem just pull out RAM and clean it then insert it and do the process again.
Feb 07, 2014 | Toshiba Satellite M115-S3094 Notebook
Preasrio f557us wont boot past the XP screen
Ram was your best bet on a laptop. But you can load XP onto itself so it reloads without deleting any files. However, if it still may fail. If that happens a clean install is your next step.
May 09, 2013 | Compaq Presario F557US Notebook PC -...
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
Toshiba NB100
Hi there. If you already tried using other options from the windows advanced option and nothing works then you laready have a corrupted Operating system. Your hardware is okay but you just can't boot to windows since it's corrupted.
You may re-install the operating system using the recovery cds that came with the machine.
Access the Quick boot menu by pressing F12 the moment you see Toshiba Logo then insert the Operating System recovery cd. Use the up or down arrow keys to select DVD/CDRW, press Enter and keep tapping the spacebar until you see windows is loading files. If your OS (operating system) is a Vista, you will see Windows set-up EMS enabled hig-lighted... press Enter and you'll see "Windows is loading files".
If you're re-installing windows XP, just follow the instruction on the blue screen.
If you're re0installing Vista, get back to me so I can give you further instructions.
^_^
May 13, 2010 | Computers & Internet
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
I have a dv6000 laptop HP. I turn the power on. It bring to my password page. I enter my passoword. Desk top show up and then all the sudden a blue screen shows up with alot of numbers and letters for...
This is usualy called "BDOD" as in "Blue Screen Of Death", more exactly a blue screen containing some error codes, some description of what was going on when it ocurred and a restart signal. You can't see the blue screen for more then a split second because by default the computer is set to restart automaticaly when these errors occur.
Mostly these errors appear as a result of a software modification that alters how windows executes a certain system file. It's actually hard to figure out what does the error means as long as you can't see it. However you could try running an older version of the windows core system registry by System Restore, if you have it enabled (it's on by default). By this we hope to restore the registry to a state prior to this problem.
You can do this by pressing F8 key when the computer is booting up, just before the windows logo appears (or that green bar in vista). When pressed at the right time, this key will bring up a menu on wich you would need to select "most recent settings that worked" or similar - depending on your windows version.
This will instruct windows to load some older registry configuration, one that worked in the past. If you still receive the same error, you could try booting in Safe Mode (again, press F8 but this time select "safe mode") and try unninstalling recent installed aplication, because maybe one of them is causing your problem.
If these steps woun't work, the only clean way to solve the problem would be to reinstall Windows along with your other software programs.
Hope these tips help.
Bogdan
Jul 04, 2009 | HP Pavilion dv6000z Notebook
I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Feb 24, 2009 | Apple iPod touch
98 loading error message
When you format something you WILL lose all of the data that was there. I would also recomend upgradeing to XP, 2000, or NT. You may need to reinstall the OS. If you need instructions ask me and I can help.
RCF
May 29, 2008 | Microsoft Windows 98 for PC
Icons on the internal screen?
GSM Network Strength. Or Missed an incomiing call.
Feb 26, 2008 | Sony Ericsson Z310i Cellular Phone
Toshiba Libretto 50CT Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
