Question about KitchenAid KUDR24SE Built-in Dishwasher
Kitchenaid dishwasher KUDR24SE...cannot open door
Door handle seems to be loose/broken....cannot get door open to do any sort of repair. any help on how to get the door open would be helpful.
Thanks
Did anyone have a solution? i have the same problem.
Posted on Nov 22, 2009
KUDR24se broken handle door locked - how to open for repair
Hello, Thank You for using FixYa. I will be helping you today.Just open the door and remove the screws around the top panel and pull the control off starting at the top. It can be hard to get off at times but thats how it comes off.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | KitchenAid Dishwashers
How do you open door when handle is broken? The handle is loose, not attached.
That the handle out by gently pulling one side out, then take vise grips and pull the little wire that attaches to the handle.
Jun 12, 2011 | KitchenAid KUDI24SE Built-in Dishwasher
The handle opener on my my Kitchenaid whisperquiet dishwasher is completely loose and I can't open the dishwasher to remove my clean dishes. What can I do???
The idea is to lift up on the part of the latch that is fixed to the body of the washer. The door part of the latch slides under this peice. If the handle mechanism is broken, it will not depres the door part of the latch to allow it to open. therefore, we have to pickup the latch part fixed to the body.
To get the door open, take a clothes hanger and cut off a 12" peice with a pair of pliers. Bend the last 1.25" at 90 degress angle. Make another bend about 4 " from that to make another 90 degree angle. This will give you leverage. Insert the first bent end between the top of the door and the counter. Rotate it so that the end is facing down. Feel for a metal plate. When you hit the plate with the probe, turn your hanger so that it lifts up the plate and simultaneously pull on the door handle. The door should come open.
Now you have to get the handle repaired, but at least you know how to open the door.
Oct 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Cant open dishwasher doorany hints?
In order to release the latch mechanism you need to either get inside the door or you need to get to the top of the cabinet of the dishwasher. The screws that hold your dishwasher into the cabinet are up under the lip of the cabinet. The door may be in the way of getting a screwdriver in to get the screws out so that you could slide the dishwasher forward to see the latch on top of the case of the dishwasher. You might be able to get a right angel screwdriver into the space between the door and the cabinet and work those screws out. You may have to remove the bottom panel on the dishwasher and screw the legs up a bit in order to pull the dishwasher forward. If you get the dishwasher forward, you may have to disassemble the latch mechanism enough to get the door open. Then comes the problem of figuring out what caused the latch to stick. I hope this will help you resolve your immediate problem
May 12, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
KUDR24SE hinge springs have broken, how do I get in to replace them?
You have to remove the screws holding it to the counter top and slide the dishwasher out about 1 foot and you'll be able to reach the springs at the bottom on each side.
Mar 07, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Door handle will not engage with latch to open door.
yea but the trick is the latch acces is behind console not the front panel, you need to unistall the d/w slightly to remove strike plate holding broken latch closed, door needs to be opened to gain access to console screws
Feb 22, 2008 | Dishwashers
Dishwasher door latch
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Aug 03, 2006 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
283 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
