Question about Jack Lalanne Power Juicer 250 Watts
Red mesh blade
Where  can i buy a new blade the spinning one
I saw one for auction on eBay. <a rel='nofollow' href="http://cgi.ebay.com/Jack-LaLanne-Power-Juicer-Replacement-Parts-Kit-1-NEW_W0QQitemZ260179789909QQihZ016QQcategoryZ20677QQssPageNameZWDVWQQrdZ1QQcmdZViewItem"target=_self<Click here.</a>
Posted on Nov 07, 2007
  • Anonymous Nov 07, 2007
    Grrr...sorry about that jacked up link. Anyway, you can get one on eBay.
I need a cutter blade parts no 015180. Can I pay for it on the net?
You can buy it from Waring or Omega, same blade.
Or, just google Acme juicer parts. $20 to $30. Look
out though, found new blade increases vibration. You
can also sharpen old blade by slightly drilling into
each burr on the blade with a small drill bit. Been
using the same blade for several years.
Jan 28, 2011 | Acme 6001 Juice Extractor
I cant remove the blade or mesh basket to clean it.
you need the orange crescent shaped tool to loosen the filter
Jun 28, 2010 | Jack Lalanne Power Juicer 250 Watts
How to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Mar 15, 2010 | Salton Juicers
Pusher is too long
Buy a file or sandpaper from a hardware and file off the part that touches the blade. I've done this no prob.
Jan 08, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
I bought the juicer at a second-hand store in brand new condition however the crescent tool was missing. To remove the flat blade for cleaning, I use a pair of scissors spread far enough to fit the ends in both holes. Hold the basket still while turning the scissors counter-clockwise untill the flat blade detaches. Easy as that! I ordered the tool, but it hasn't arrived yet. Hope this helps!
Oct 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Need a new mesh filter for Jack Lalanne Power Juicer
On their website there is a manual and at the end of the manual there is a number you can call for a replacement. I believe you get the crescent tool, blade, and filter together for around $25. http://www.powerjuicer.com/customer-manuals.html
Apr 26, 2008 | Jack Lalanne Power Juicer 250 Watts
The blade will not spin when the top piece is secure, & I the inside will not come out to clean
There is a roll pin under the flywheel, I you can get the basket off then you pull up on the flywheel , It is the last part before the motor housing. Once you have that off I think you may find that pin is sheared off. It is a common automotive or bearing house part. push out the old and push in the new pin and away you go. The new pin shoud protrude about 3?16 " on both sides of the pin. I hope this helps.
Dec 27, 2006 | Acme 6001 Juice Extractor
Jack Lalanne Power Juicer 250 Watts Logo
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
