Question about Hitachi 53UWX10B 53" Rear Projection Television
Magic focus 4 error
What does the magic focus 4 error mean? on a Hitachi rear projection tv
Error 4 is listed as an overflow in the convergence section.
To fix:
1. Check the placement of the sensor
2. perform an Adjustment check of th H/V size & centering
3. Conv. amp. gain check, check these resistors:
R041, part # 0790024R, RES.CHIP 1/16W 100 OHM
R046, part # AQ00164R, RES.CHIP 1/16W 75 OHM TAPE
R050, part # 0790059R, RES.CHIP 1/16W 47K OHM
R058, part # 0790054R, RES.CHIP 1/16W 18K OHM
R062, part # 0790047R, RES.CHIP 1/16W 5.6K OHM
Posted on May 15, 2010
Vertical position does not work on remote. Magic focus on green goes half way stops then number five comes on screen. Hitachi 51inch rear projection tv
Magic focus on a Hitachi only adjusts at 16 points on the screen and needs to be done in a dimly lit room. Frankly its a sales gimmick, the number 5 means one of the sensors inside the screen for the Magic focus is not connected or bad.
Go into the tech mode for convergence with the original remote (that menu is called the Decam mode) and see if convergence will adjust there. There are close to 120 points that can be adjusted there as opposed to less than twenty in the magic focus mode.
Dec 23, 2012 | Televison & Video
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
What does it mean when you get a error code 5 when you are doing the magic focus?
Mean ur tv convergence board it is dead,any codes error at all,mean the tv convergence board have components it is dead and the board it just dosen't conververt it three CRTS tv colors Tubes like R,G,B colors lines yokes anymore.Now.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.After the tv fixed it convergence board,the tv will run the entire Magic Focus function,without any error codes at all.The tvs shops will cost u like $300-350 for parts and labors.
Jul 10, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Out of focus and the magic focus will not finish and give a 4 on the botton right of the screen
Hitachi tv magic focus will not finish and the picture is out of focus, what part needs to be replaced?
Jan 05, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
My hitachi 53udx10b tv is out of focus.
rojamon,
That #4 error is listed as "overflow," and I got a"ROM overflow" errorwhen I tried to save my adjusted convergence data.I don't know whatthat all means yet, but if I figure out my problem,I'll post backhere. I've read here and elsewhere that the out-of-focusproblem comesfrom bad resistors or amps on the convergence board. Youcan tryservice mode to adjust convergence. Press the Magic Focusbutton, andthen press it again to stop it, and then press the Statusbutton onyour remote. Here's a link to the manual convergence procedure (scroll down).
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
Dec 15, 2008 | Hitachi 46GX01B 46" Rear Projection...
Hitachi 51G500 big screen rear projection tv
Is this a new television? Under warranty? You need a service call.
Aug 07, 2008 | Hitachi 51G500 51" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue and Green Bar
run magic focus, If you get a error 4 during the magic focus, that is often an issue with the convergence
Feb 01, 2008 | Hitachi 51F500 51" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
607 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
