Question about Dell Inspiron 6400 Notebook
Cannot get by dell screen to come back on once it hibernates
After my Dell Inspiron 6400 is idle for a while, the screen goes off. I cannot get it to come back on at all. The power is still on, but I must shut down with the power button.
I have tried using the FN button and the Stand by, Hibernate, battery, etc.
i have tried changing the the startings as well. Any suggestions.
  • Frank Zhang
    Frank Zhang May 11, 2010
    take away the battery , power on by adapter ok? do you hear the fans or HDD spin inside?
  • 29 Answers
Sounds like a power scheme setting is shutting off your monitor after a time-out period. sometimes monitor will not return without re-boot. change your power options settings in control panel.
Posted on May 26, 2009
My dell inspiron n5050 automatically hibernates after booting
on start up togglr F8 key when screen comes up choose start in safe mode once it gets to main screen right mouse click in center of scren pick personalize click on screen saver and go to change power settings and see what hibernation is set on and set it higher restart and see if problem is solved
Jan 19, 2013 | Dell Inspiron Computers & Internet
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
I HAVE INSPIRON 6400 LAPTOP. ON SWITCHING ON SCREEN SHOWS BLUE & ORANGE WORDING OF DELL LOGO AND THEN GOES BLANK. IT WORKS WHEN USING AN EXTERNAL MONITOR.
Run the LCD BIST Test
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=04&l=en&s=bsd&dn=1092705
If it passes, replace the motherboard, fails replace the LCD
May 17, 2010 | Dell Inspiron 6400 Notebook
My laptop monitor goes dark
Hi there! Try this trick...
You can adjust the screen brightness within BIOS set up...
It works with Dell!!!
^_^
May 13, 2010 | Dell Inspiron 6400 Notebook
How do i re-activate hibernate and standby on my dell inspiron 6400. both used to be available but after having it repaired i can't seem to find a way to reactivate them
Type cmd into the start menu search box, and use Ctrl+Shift+Enter to open in administrator mode. You can also right-click the item in the menu and choose Run as Administrator. From the command prompt window type the following command
powercfg /hibernate on
restart your computer and it will take effect.
Dec 19, 2009 | Dell Inspiron 6400 Notebook
I have a dell inspiron 6400 and im getting a black screen once the dell logo comes up and windows xp loads...I see no icons or nothing..just a black screen
it sounds like your display backlight has gone bad. If your handy you can get a new display. If you are really good you can replace the back light.
Nov 07, 2009 | Dell Inspiron 6400 Notebook
My friend owns a dell inspiron 1545 that is less than a year old, but whenever she goes on the internet it randomly goes into hibernation and she has to log back in. She's tried doing system restore but it...
right click on open area on the desk top. Go to properties - screen saver - power monitor - go to the hibernate tab - uncheck enable hibernation - click apply then ok.
Oct 03, 2009 | Dell Inspiron 1545 Notebook
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
2 very annoying problems.
plz stand by is just a power safe option for ur laptop. with some laptops when u shut the screen they hibernate with others they go to stand by and others too shutdown. and the power button on ur machine is also configured to shutdown ur machine when its being pressed. u can change these setting in the control panel\power options. hope it solves ur problem
Apr 09, 2009 | Dell Inspiron 6400 Notebook
Dell 1721 fails to boot
do a hard shutdown by holding the power button down until all the lights and power go off. reboot and then right click on the desktop and select properties. go to the screen saver tab and then the power tab set the side when it is plugged in to never turn off monitor, never turn off hard disks, never go on standby. Of course you can set other time limits, but remember that it will go back to hibernating if the limit is exceeded.
hope it helps
Nov 02, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
136 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
