Question about Sony STR-DG500 System
Selector knob broke off i need to get a replacement and info on replacing
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    What is the exact model number of your Sony receiver to find out input selector knob part number.
WHERE CAN I BUY REPLACEMENT PART WASH SELECTOR-
perhaps the manufacturer .I see none listed
Oct 21, 2015 | Washing Machines
Why wont my 2001 ford windstar blow out of vents ? only on defrost?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • You probably have a vacuum leak , Pull heater control panel an check for vacuum . A broke vacuum hose or The vacuum selector valve is bad ! Or check for a vacuum hose in the engine compartment being off somewhere !
Mar 08, 2015 | 2001 Ford Windstar
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
2011 Town & Country gear selector knob "cap" needs replacing
If it's not on Ebay or Craigslist you best bet is the dealer or if you get lucky try a few salvage yards. That's a dealer part
Jul 25, 2014 | 2011 Chrysler Town and Country
I have an older a/c model no. A494901 (?). The control knob broke off. Is it very hard to replace it with a new knob? And, where would I get a new knob? Thanks, -Fran O'Neill
Depending on your break is the stem leading from the settings selector switch still there or did it break to. If it broke as well you will need to replace both the selector switch and the knob. If not the knob can be obtained from your local Sears Repair Center.
Jul 05, 2011 | Kenmore Heating & Cooling
Center Knob broke off (menu/channel selector). Is this knob replacable?
I'm not sure if it is. Usually it has a small contact inside it. If you culd work a knob back in it to get temporary contact to change it. Maybe it would be costly to take it to the shop to get one soldered in. Radio techs make $18-30 dollars an hour. They will fix it for you but will cost you.
Mar 24, 2011 | Cobra Radio Communications
I am looking for a cooling knob selector. the knob broke and no local hardware store has this knob. Can you please help me in finding a colling selector knob
If you try with electronic spares shop, you will be able to get some replacement for the knob. A universal type can always be fitted and you can source this even from the gas/oven spare parts stores.
Also if you check with any AC repair shops the knob can easily be salvaged from an old non working set. I am sure you can find one from any of these shops.
Hope my advice helps. Good day
Aug 17, 2010 | Sunbeam SCA052MWC1 Air Conditioner
MY KNOBS ON THE RIGHT OF THE REACEIVER BROKE OFF.... 1 FOR BASS AND TREBBLE ONE FOR IMPUT SELECTION HOW CAN I GET IT FIXED
that depends if the knobs or the shafts are broken.the knobs are easily replaced as they just pull off. the controls is a different problem as they are soldered into the pc board.the input selector switch will have alot of pins and the bass and treble 6 pins each.the front panel has to be removed,the lock nuts taken out and sometimes the input selector has a small pc board that is wired to the main pc on a connector,and the replacement comes with the pc board.the parts can be got from sony parts or an authorized repair depot.unless you are really good with electronics,it is best left to a pro to fix,the power supply in that unit runs on over 100 volts dc
Apr 26, 2010 | Sony STR-DG910
2006 trailblazer 4x4 dash switch.
How to replace the 4x4 selector on an 04 envoy
Dec 23, 2008 | 1994 Chevrolet S-10 Blazer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Sony STR-DG500 System Logo
126 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
