Question about Sharper Image (SI714SL2) Compact Refrigerator
Sharper Image Mini Fridge is not getting power from what I can tell. Any suggestions?
4 Suggested Answers
  • 3 Answers
SOURCE: Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Posted on Nov 26, 2008
  • 54 Answers
SOURCE: sharper image power tower 200
There is a small 1 1/2 inch O ring style belt that connects the motor to a set of gears. This belt is most likely broken and needs to be replaced.
Posted on Aug 05, 2009
  • 5 Answers
SOURCE: I own a Sharper Image eVac. It came without a manual.
I just got a eVac from craigslist today 12-22-09. Fairly new only been run a handfull of times maybe. This came with a manual but theres not much to it. (15 pages) It is supposed to run about 45 min to a charge and its good to let the battery run all the way down before recharging.
I got a half hour runtime after a couple shorter runs that didnt hold charge very long or didnt run becuse there was a brush sensor error.
I believe these types of batteries are best stored for long periods with some charge left on them, otherwise run it down all the way before charging. Manual says battery temp is a factor in how long it takes to charge, im guessing hotter = longer.
Filter is cleanable with water. No detergent. Fan can be air dusted clean too.
These are my findings after 1 day.
This one didnt want to go on carpet very long before stopping with a "brush error". The 5 small screws that hold the black plate with the red brush sensor window that is directly above the brush comes out easily and exposes the brush sensor in the middle which is quite fragile but can be air dusted clean.
A magnet is good to have on hand, the screws are tiny. With the plate off, I also gently aligned one sensor to be slightly more parallel to the other. This also helped reduce the brush error.
Note which side comes out first because it will want to go back in the same way it comes out. If forced in, this is where you can potentially bend the sensors and undo your careful adjustment and cleaning of them, This is the most critical step so take it slow and have plenty of light to see that no sensor gets pushed askew. Its like Operation The Wacky Doctor Game ...in reverse, dont touch the sides of the window to the sensor...bzzzt!
Posted on Dec 22, 2009
Replacement Power Supply AC Adapter Sharper Image SI601 S1601 51601 Travel Sound Soother 20 with LCD Alarm Clock your problem?
I also am looking for a replacement power AC adapter cord for a Sharper Image SI601. I tried a radio shack replacement, and it works about 50% of the time.
Thanks!
Chris
Aug 07, 2012 | Sharper Image Travel Soother 20 Clock...
I have a Sharper Image Powered Subwoofer SA251 and it started making a steady harmonic loud sound, turned it of and on and still had the same problem. I also unplugged it and pluged it back in and still...
Subwoofers are basically single mono amps. In your case it could be caused by a faulty electrolytic capacitor or a defective power output device.
If you can't do the job yourself, then any decent electrical service shop should do it for you.
Nov 27, 2017 | Sharper Image SA251 Subwoofer
My sharper image eca115 does not work properly with my 3rd generation ipod nano.... sound only comes out of one speaker. please advise
Are you connecting with mini cable? make sure you have right cables... Apple uses a 3 ring mini end where most mp3 players use a 2 ring connector
Jan 02, 2011 | Sharper Image The Rotating Speaker System...
Nov 21, 2008 | Sharper Image Professional Plus Ionic...
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Sharper Image Jumbo Universal Remote
i just pirchased a Sharper Image Jumbo universal Remote but i can't find a code for the Pioneer DVR 541H is DVD recorder. Does anyone have this code or  a suggestion?
Jan 10, 2008 | Televison & Video
Sharper Image (SI714SL2) Compact Refrigerator Logo
181 people viewed this question
Top Sharper Image Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Sharper Image Refrigerator Expert? Answer questions, earn points and help others
