Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpoole gold top loader stop working
Our whirlpool gold ultimate II model gst9679pw1 washer stop working. at first it started out it would fill up then shut off , so we would have to tug on the setting knob to restart it. now that no longer works. I was able to get the water to drain out but the load was never washed.
  • steve
    steve May 11, 2010
    Bad timer.
    President:
  • 3,113 Answers
Try pushing down on lid switch. common problem for these models.
Posted on Sep 28, 2009
5 Suggested Answers
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 34 Answers
SOURCE: removing timer knob from whirlpool
If you look at the back of the timer lined up with the center of the Knob there is a black or gray plastic part pull that out about an inch then the kbob will come off
Posted on Jan 03, 2009
scottowa
  • 87 Answers
SOURCE: how to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Posted on Mar 29, 2009
SOURCE: How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Posted on Jul 14, 2010
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
Hi.
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Door switch problem top loader
I fixed mine with a toothpick and a piece tape. Make the tab on the door longer that activates the switch. Try triming the lid bumpers
Apr 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer has begun to make a loud buzzing sound when the
This machine has an end-of-cycle buzzer built in. It may be that it just started working.
Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
387 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
