Question about Dyson Flowcheck CRO1 Front Load Washer
Dyson cr02 fault f11
My machine did a wash and then came up with the F11 fault before it had done the final rinse and spin. It just fills and drains the water out when I try to restart it and comes up with F11 message. Is it worth repairing as it is in very good condition. I had the Dyson guy out just before they stopped servicing washing machines and he fused the drums together and it has worked fine until now.
jonniewalker
  • 1031 Answers
SOURCE: dyson cro1 fault f11 came up after interupted power suply
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
The F11 fault is a fuse blown on the circuit board.
Apparently this fuse failing can blow the board so you may have to change the board if needed. The board is located at the back of the machine so you need to take the back off, unplug the board, change the fuse which you can buy at Maplins and put the board back.
If it works fine, if not then you need a new board. Hope this helps you.
First make sure machine is turned off.
Second press & hold temperature button .
Thirdly press the on button & hold at the same time as the temperature button.
Fourthly release the 2 buttons at the same time .
Fifthly press the soil button .
Sixly turn machine off then back on & F11 message saying fault F11 must disappear.
if not try this process once again. if the error is not cleared then you will have to do as i have said you earlier.
Posted on Jan 18, 2009
taran_2005
  • 10515 Answers
SOURCE: how to repair a F 11 fault on a DYSON CR01 flow check
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Thanks for using Fixya.
Posted on May 28, 2009
  • 4 Answers
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
Posted on Sep 17, 2009
Dysonteam
  • 167 Answers
SOURCE: Dyson washing machine fault code f11
Hi its Darran at Dyson.
So that we can assist you, please contact our Helpline on 0800 298 0298 so that one of our advisors can run through some checks with you as you may need an engineer.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
Dysonteam
  • 167 Answers
SOURCE: dyson washing machine fault
Hi its Darran at Dyson. If you paid for a repair then there is a 12 month guarantee on any work that was carried out. To arrange a visit, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Posted on May 24, 2010
I HAVE FAULT F11 HOW DO I FIX IT
Dyson Memory CRO1 Front... Fault f11 Solutions - Fixya
www.fixya.com > ... > Dyson > Dyson Memory CRO1 Front Load Washer
Dyson Memory CRO1 Front Load Washer, fault f11 related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Flowcheck CRO1 Front Load Washer
Dyson repair manual
Hi there, it's Jack at Dyson.
An F11 fault code means 'no motor action'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Aug 11, 2014 | Dyson Memory CRO1 Front Load Washer
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
3, Power on
May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cro1 fault f11 came up after interupted power suply
Jan 18, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer Logo
37 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
