Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
Removing starter-cnat get it to drop out
How do I remove the starter on a 96 chevy 2500 truck. I have removed the two starter bolts but can't get it to drop.
There is another bolt at back of starter which is bolted to engine block and starter.
check it out
Posted on Jul 19, 2009
Remove & install water pump on 1995 chevy 2500
straight forward job. Remove the fan shroud, loosen the fan bolts before removing the fan belt, remove the fan, the hub, drain the coolant, remove the hoses, remove the water pump mount bolts etc.
Jan 24, 2015 | 1995 Chevy 2500 Pickup Truck Grill with...
1995 Chev 2500 will not start
The rotor and wheel bearing come out as an assembly. First put the axle nut back on tight before you do any hammering unless you want to put on a new wheel bearing anyway. If you hammer it with the nut off you risk the chance of separating the bearings in the hub and destroying it. Dont forget to remove the 3 or 4 bolts that hold the wheel bearing in from the back side. Once you get the hub broke loose from the truck then remove the axle nut and remove the assembly. Be careful not to break the abs sensor or wire. To remove the rotor from the hub place the assembly on the bench and drive out all of the lug bolts and the rotor will drop right off.)) I agree with this, good answer, and easy on the hammer.
Parts For Porsche Boxster
Jun 11, 2012 | 1995 Chevrolet C/K 2500
How to change the Starter on a 1989 toyota camry
Starter - REMOVAL & INSTALLATION
Gasoline Engines
  1. Disconnect the cable from the negative terminal of the battery.
Fig. 5: Exploded view of the starter motor mounting-5S-FE engine shown, others similar
  1. On 1992-96 models with cruise control, remove the battery.
  1. Also on 1992-96 models with cruise control, remove the actuator cover and disconnect the wiring harness. Remove the three bolts and then lift out the cruise control actuator. Remove the bracket from beneath the actuator and put aside.
  1. Peel the rubber boot away and remove the nut and disconnect the negative battery cable from the magnetic switch terminal on the starter. Disconnect the electrical connector also located on the magnetic switch.
  1. Support the starter by hand and remove the two mounting bolts.
  1. Remove the starter from the transaxle.
To install:
  1. Place the starter motor in the transaxle and support by hand.
  2. Install the two mounting bolts and tighten them to 29-31 ft. lbs. (39-42 Nm).
  3. Connect the connector to the magnetic switch. Place the battery cable on the switch terminal and install the nut. Tighten the nut and position the rubber boot over the cable.
  4. Using the ignition switch, "bump'' the starter over a few times and check for proper operation.
Hope helps.
Aug 11, 2010 | 1989 Toyota Camry
1988 Chevy Tahoe Starter going out. Need to replace
Generally starters have 2 or 3 bolts and a thick wire coming from the battery and other miscellaneous connections.
You did not specify a vehicle that was on my list, i.e. 1988 Chevy Tahoe.
However, it may be similar to a Suburban R10:
REMOVAL & INSTALLATION The following is a general procedure for all trucks covered in this manual, and may vary slightly depending on model and series.
  1. Disconnect the negative battery cable at the battery.
  2. Raise and support the vehicle.
  3. Disconnect and tag all wires at the solenoid terminal. NOTE: Reinstall all nuts as soon as they are removed, since the thread sizes are different.
  4. Remove the front bracket from the starter and the mounting bolts. On engines with a solenoid heat shield, remove the front bracket upper bolt and detach the bracket from the starter. Fig. 1: Starter mounting location — 4.8L engines 84903021.gif
    Fig. 2: Starter mounting location — 4.3L and 5.0L engines 84903022.gif
    Fig. 3: Starter mounts — 5.7L and 7.4L engines 84903023.gif
  5. Remove the front bracket bolt or nut. Lower the starter, front end first, then remove the unit from the truck. To install:
  6. Position the starter and tighten all bolts as follows: R/V Series:
    • Thru-bolts: 40 ft. lbs. (54 Nm)
    • Bracket bolt: 30 ft. lbs. (41 Nm)
    • Nut (gas): 11 ft. lbs. (15 Nm)
    • Nut (diesel): 90 inch lbs. (10 Nm)
    C/K Series:
    • Thru-bolts: 35 ft. lbs. (45 Nm)
    • Bracket bolt (diesel): 24 ft. lbs. (33 Nm)
    • Nut (diesel): 75 inch lbs. (8.5 Nm)
  7. Reconnect all wires. Fig. 4: Disconnect the negative battery cable 87982p25.jpg
    Fig. 5: Remove the starter retaining bolts 87982p30.jpg
    Fig. 6: Remove the starter from the vehicle 87982p31.jpg
Jul 19, 2010 | 1984 Chevrolet Chevy
How do I replace a starter on a 1993 chevy pickup truck
You'll want to disconnect the positive battery cable from the battery. Remove the 14mm or 15mm nut holding the battery cable to the starter, and the 8mm nut holding the small wire to the starter. Remove the 2 14mm bolts going up thru the starter, into the block.
Jun 13, 2010 | 1993 Chevrolet C/K 2500
How do you remove the starter on a 6.0 chevy engine?
Not too difficult. Remove negative battery cable. remove battery cable from big stud on starter selonoid. Remove small wit from "s" terminal on starter selonoid. Remove starter retaining bolts, and lower starter down.
Apr 07, 2010 | 2003 Chevrolet Suburban 2500
I need to replace the fuel pump how would i do that in a chev silverado 2500   02   do i have to drop the tank and pull it out from the top?
either drop the tank or remove the bed, I have worked on some chevy trucks that you HAD to remove the bed as the bolts that hold the tank were inaccessible.
Feb 14, 2010 | 2000 Chevrolet 2500
What is easiest way to get the starter off a 96 blazer?
disconnect battery, lift truck, put on jack stands, locate starter under truck, remove wires, remove bolts holding starter to block, be careful not to drop starter, it is heavy
Oct 12, 2009 | 1996 Chevrolet Blazer
I can't remove the starter from my 84 Caprice Classic.
yes you have to drop the exhaust pipe and disconnect the battery
May 12, 2009 | 1984 Chevrolet Chevy
96 Chevy S-10 starter problems
Just did this, take the long bolt out of the passenger side engine mount, loosen the two transmission mount bolts and jack the right side of oil pan slowly, when you do this there will be enough clearance between the bell housing and frame, be sure to use a jack stand to be safe.
Put the starter motor in the space with the selonoid up and wiggle forward into position then insert bolts and hook up connections. Let the motor down, put the motor mount bolt back in, tighten transmission mount.
Apr 16, 2009 | 1996 Chevrolet S-10 Pickup
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
189 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
