Codemasters Clive Barkers Jericho (Playstation 3) for PlayStation 3 Logo
Coen Biglove Posted on Dec 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fails to respond to start button at screen that asks to press start button
Got this game as an early christmass pressie, starts ok, and can exit ok, just cant get it to go beyond the screen with press start button on the bottom
stargajzer
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Dec 22, 2013
stargajzer
Expert
Level 2:
Cheetah:
Answers
79
Questions
0
Helped
24325
Points
144
Check the disc for surface smudges finger prints.
Virtual karts in dosbox keeps showing sound config screen
Erik,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
4helpful
Unable to clean 46 in brother mfc 6490cw printer machine
  • Press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
  • Enter maintenance mode 80, by pressing the up/down arrow key and set key to select numbers 8 and 0
  • Press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
  • Use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter.
    Press Stop/Exit key to go to root of maintenance mode.
  • Enter 9,9 to exit maintenance mode
2answers
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
I just purchased a new surround sound systemm and everything says I need a disc to get started but there wasn't any disc in the box ?
hi,
there is no need fo any disc. u can make the setups manually. make all the connections try the following.
Press [DVD] to select "DVD/CD".
Press [START] to show the START menu.
Press [up, down button ] to select "Setup" and press [OK].
Press [,up, down button ] to select menu and press [OK]
Press [up, down button ] to make the settings and press [OK]
Press [up, down button] to select the item and press [OK]
To return to the previous screen, press [RETURN].
To exit the screen, press [START]
The settings remain intact even if you switch the unit to standby.
ok
After pressing the audio button on my psp the screen would go black and white from bottom to top then would go back to normal what i tried is to take out the memory card and tr to press the audio...
Hi, I've had the same problems for about a month now. I have a psp fat (psp-1000) with cfw. 5.50. I was playing ZHP unlosing ranger when the same thing happened.
I use the lowest brightness setting to lengthen game play time. I keep using the audio button (The one you hold and turns the sounds mute or back.. right?) for the game then when i reset my game (press home and start the gameover..) the brightness suddenly keeps on changing even making the whole screen black. After 5 minutes? it stops but then when i press the down or square, triangle button the brightness changes sometimes thats the only thing the button does.. i found a temporary fix for this, i put it sleep mode then turn it on again and it stops.. the buttons go back to normal, for a while.
It goes on and on even with other games. It just stops after 10 minutes later or more than starts happening again everytime the brightness or audio button is pressed.
We scanned it for viruses on a computer and it just kept on blinking everytime it responded to the scan. No virus were found but after that when we disconnected it from the computer the brightness problem stopped for a good long time.. we avoided pressing the brightness and audio buttons. but recently its happening again.
and now just got worse. I was playing Socom Fireteam, and when you accidentaly go to the start menu, you have to press "select" to exit and continue the game. But the "select" button wont work!
so i quit the game and startover.. when this happened for the 3rd time. When i pressed "home" button and was asked if i really wanted to exit the game i couldnt move to "yes" and couldnt press the "O" or "X" buttons.
So i turned off my psp and when it went back on, I couldnt press anything anymore. except, the volume buttons and select (the vsh menu appears)
I searched for help from the internet, found "disable your vsh menu" remedy.
It worked! but when i played the game, the "cwcheat" menu keeps on appearing (seplugin that appears when you press select button). It wouldnt stop >.<
So we disabled that too.
Now playing God of War Ghost of Sparta, and one part, the start menu kept on appearing! we'd close it so that we could push one of the levers in the game but then it pauses the game again.. it stopped after a while. then it happened again only slight.
Found a comment on a "select button problem" and it said that it was the:
"parts that were Ribbon style, with it was the start and select button and the volume/sound" he had that parts?
found same problems around the net, some posts from 2009.
found decent posts and solutions here:
http://forums.qj.net/psp-general-help/151111-psp-slim-start-button-stuck.html
the best one says buy a new "flex bar" or "home bar". It goes by many names, but it's the metal bar that has all of the bottom row buttons on it (home -> start) It's usually under $10 USD and obviously the right thing to do.
got another comment that says it worked from him when he bought one himself.
Glad I found others, and that I could share this.. wish it makes things better.
Hope it works out for all of us!
Another thing, Merry Christmas!
My GE Profile model WPRB8050D0WW won't start!
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
3helpful
2answers
Action replay not responding at all
how to reset the Action Replay DS OK we have finally done it!! YEAGH!. Here is the trick for those like my son and I that are trying to get the darn thing to reset. All you have to do is Hold down A&B first while the unit is off. Keep holding A&B buttons then be ready to press the Start & Select button just after you turn on the DS. Wait for the White screen to Appear after bootup, then press and hold the Start & Select buttons while still remaining to hold the A&B Buttons, before the words appear. Another words after health and saftey screen a white screen will appear that is when you add the start & select buttons along with the A&B Buttons. The white screen will stay on for 10 seconds. If it does not stay on the white screen foe about 10 Seconds, it did not work. Otherwise ours did not work until we jumpped the gun on the Liscense screen. Hope this helps someone. :)
Want to reinstall to factory settings
As the pc is booting press F2 or Del (dependant on bios) and enter bios set up.
Choose to make your cdrom as first boot device, save settings and exit bios.
Insert cd drive before the boot up starts and there will be a screen prompt to "press enter to boot from cd", press enter and then the cdrom will go to the next step, asking press 'R' to repair or press 'Enter' to format and install windows, choose repair if you have documents you need on your pc.
The system will then go through a full repair installation, when complete your system will be repaired and everything should be as before with nothing lost.
You may have a faulty hard drive so if you cannot get windows to repair it will tell you theres no drive found.
Won't boot
Try pressing F8 as your machine gets ready to start windows. Keep tapping it until you get a menu. You can try "most recent settings that worked" or failing that try starting Windows in safe mode. If it will start in safe mode regress it to a point before your failed download using System Restore. If it won't start at all, you may need to reinstall Windows.
3answers
Touch Screen Issue
Hi Troy, same problem with my 2610, It seems to be related to a voltage problem in my ford f-150 07. When starting the truck I think it sends current the wrong way because if i start and turn off the truck it goes back to normal, the problem comes back if i start the truck with the 2610 on. If this can help, the garmin tech also told me about the 225$ repair. Try turning the unit on and off and also your vehicule. Once it is ok, dont forget to turn the unit on and off while the car is on. It worked for me. I also know that this is not a definitive solution but it can help. Patrick
Top Codemasters Video Game Consoles & Games Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Alex
Alex
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
