Question about Compaq EVO T30 Network Terminal
Compaq EVO t30 boots to Citrix client
I have a Compaq EVO t30 that I acquired. I want to be able to use it was a low-cost web browser only machine on my home network.
Currently it tries to boot to a Citrix ISA client (left over from a bank I think, as it says Desktop Teller west).
Is there a way I can somehow get it to boot to its native operating system (windows embedded) without first loading the Citrix client?  Is there some secret keystroke that gets it to boot in safe mode? or something like that?
I saw a bunch of posts on how to convert it to Linux, but wouldn't be easier to just modify its equivalent of its autoexec.bat file?  If so HOW?
  • 3 more comments
  • Iam Onthenet
    Iam Onthenet Dec 02, 2007
    Where's the solution country?
  • Iam Onthenet
    Iam Onthenet Dec 03, 2007
    This helps, but I have already seen those links to HP sites.
    I cannot tell what embedded windows is on the box, as it boots directly to a citrix login and I cannot get around that.
    I tried using rapport to remote manage, but then all I got was a VNC screen that was asking for a password that I do not have..
  • Iam Onthenet
    It would be great if I can access the control panel, but like I've said several times before, it boots right to a citrix screen and I cannot do anything like that because its trying to log into the "desktop teller" system
    My original question was asking for a way to remove that sign-in screen, so that I can get to the control panel. I was hopeing that there is some key-sequence (like ctrl-F8) that would allow me into the system in something like a safe mode, where I can make the changes like you suggested.
    Thanks for trying.
  • Iam Onthenet
    This is not a computer its a thin client.
    I am not sure if you've read my comments, I cannot get to the control panel -- if I could I wouldn't be posting on this (or any) forum.
    It seems as if you do not have direct knowledge of the EVO t30..
    Thanks for trying.
  • Anonymous May 27, 2008
    I have the same COmpaq Evo T30 with Citrix Client.....same problems as Citrix boot up and I am not able to get into its BIOS even if I press F10 key. Can anybody tell the when and which key to press to get to BIOS and change the system. PS/2 mouse isn't working and USB mouse works but donot right clicks. The best thing to reinstall the operating system but I don't have the old CD now.
    Should I try Linux or something else but how can I reach BIOS????
  • 383 Answers
Platform:
  • PC (14)
  • Unix (1)
  • All
Operating System:
Posted on Dec 02, 2007
  • 2 more comments
  • sheila skaggs Dec 03, 2007
    document.tlSearch.tx.value=unescape("")
    This is why i sent ya the site so you could let me know what windows you are using, Couldnt give the solution until i found out what u have/ So im sending ya this site in which could help u out.
    You did not say what windows you are using so i can only send ya this site to re-down load and re-start over the drivers.
    Download drivers and software - compaq EVO t30
    Compaq Evo t30 Thin Client
    And this site:
    Related searches:
    Hoping this and what ive sent ya before can help u in what u r trying to figure out.
    Have a great nite and a safe week.God Bless
    Solution:
    Open Control Panel.
    1. Open the Passwords icon.
    2. Click the User Profiles tab
    3. Select the second option "Users can customize their preferences and desktop settings. Windows switches to your personal settings when you log on."
    4. Click Ok and then restart the computer.
    Enable Windows Login - If the above paragraph does not enable the password follow the below steps.
    1. Open Control Panel
    2. Open the Network icon.
    3. Under "Primary Network Login" ensure that Windows Login is selected.
    Please Note: When following the below steps, upon rebooting the computer, you may get a Network login; if you wish to remove the password never enter a password, only enter the username. Because of different setups, the user may need to do one or more of the below steps in order to disable the Windows passwords.
    Select All users in Password:
    2. Open the Passwords icon.
    3. Click the User Profiles tab
    4. Select the first option "All users of this PC use the same preferences and desktop settings."
    5. Reboot computer.
    6. After the computer boots up and no password was entered, reboot again to see if the Login:
    7. Open Control Panel
    8. Open the Network icon.
    9. Under the "Primary Network Login" change the value from "Client for Microsoft Networks" to "Windows Login".
    10. Click Ok.
    11. Once changed reboot the computer.
    12. After the computer boots up and no password was entered, reboot again to see if the changes fixed the computer. If issue persists, continue troubleshooting by following the next step.
    Delete Stored Passwords and Profiles:
    1. Start / Shutdown / Restart the computer in MS-DOS mode.
    2. Once at the prompt type cd\windows and press enter.
    3. When at the C:\Windows> directory type del *.pwl and press enter, and delete all files found. The pwl files are the actual encrypted password files windows stores.
    4. Once each of these files have been deleted, type deltree profiles and press enter. Once this has been completed, press CTRL + ALT + DEL to restart the computer.
    5. After the computer boots up and no password was entered, reboot again to see if the changes fixed the computer.
    Index
    Resolved
    If you have a cd that came with your computer Restore computer and trying the above steps in trying to remove pass words.
    Or
    If you dont need and wanting to get rid of the : Citrix ISA Client , go in to add and remove programs and remove it.
    Steps:
    start-control panel-add and remove .
  • sheila skaggs Dec 20, 2007
    Partition
    NON-DOS Partition, When using Microsoft fdisk a NON-DOS partition indicates a partition that is not native to the Microsoft operating system.
    Microsoft Windows 2000 help
    The server operating system for e-commerce and line-of-business applications. ... operating system:, Requires Windows 95, 98 NT 3.5 or 4.0 for upgrade.
    Native file format
    Native file format computer dictionary definition. ... Method used by the computer operating system or file management used to arrange data.
    IBM UNIX AIX and AIXL information
    General information and overview of the IBM AIX operating system. ... AIX/ESA, Runs native on S/370 and S/390 mainframes and is based on OSF/1.
    Visual Basic help and information
    ... includes new features such as Visual C++ 6.0 optimized native-code compiler, ... Operating System:, Windows 95 / Windows 98 / Windows NT 4.0 (with SP4)
    If one of these's site dont get it , I just dont know what esle i could send ya. Read & Follow instructions .
    Good Luck
SAP with Ncomputing, its works?
It should work fine. As long as the SAP client is 'multi-user' aware then you're good to go. One 'acid test' is to see if the SAP client will work on a Terminal Server or a Citrix Presentation server and in this case it does. The NComputing solution, conceptually at the application layer, behaves much like TS or Citrix, thus looking for those solutions is what you'll need to know for NComputing. Here is the website I found about how to setup specific INI files for Citrix to get the SAP client working. My recommendation would be to test as is out of the box with two NComputing seats, simultaneously. If that fails, then try the suggestions on this website: http://community.citrix.com/display/adi/SAP+GUI+7.10+on+Citrix+Presentation+Server.
Aug 16, 2011 | NComputing L230 Network Terminal
How do you connect ethernet so you have both your desktop and thin client connected?
Purchase a ethernet hub. I have 1 by Linksys. They are relatively inexpensive. Plug your cable modem into the uplink jack and your desktop and anything else to the other ethernet ports.
Char S.
May 20, 2009 | Compaq Evo Thin Client T30 (311335-001) PC...
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
Compaq evo 610c
Hi SusanneRenee,
The compaq would be a standalone. Just connect the keyboard, mouse, speakers, etc. and your good to go.
Hope this helps and good luck.
Jul 24, 2008 | Compaq EVO T30 Network Terminal
Compaq Evo T20 - Performance sluggish
its 16 years old now.
is this the only slow client.
after all a terminal server always serves many, not one.
if only 1 client is slow that it needs work.
what can that be,?
well , check that all software in the client are fresh and clean.
reload it?
like NIC card, driver , try another port on the router to the slow
client.
to the full reset yet and reload all software and re configure
it per the manual>?free it is, and very OLD.
https://www.manualslib.com/download/359290/Compaq-Evo-T20.html
id say the client has issues if the mouse is slow, all the time.
Dec 25, 2017 | HP Compaq Evo t20 Network Terminal
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Jun 25, 2007 | Compaq EVO T30 Network Terminal
Copy of Citrix ICA CE Client
The CE Citrix ICA Client can be downloaded from Citrix.com * From the "Citrix Downloads" section scroll down until you see "Recommended Client Chart". * Look for "Windows CE" on the chart. * Click on "ICA CE Client" to download.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Sep 14, 2005 | NEC MobilePro 750
Compaq EVO T30 Network Terminal Logo
869 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
