Question about Verizon Communications Samsung Juke Cell Phone - Red
Won't stay closed
My phone won't stay closed and pops open, is there a way to solve this?
    Problem Solver:
  • 7 Answers
I am pretty familiar with the inside of that springed hinge...its a round spring (obviously) but you should probably take it in...if its under warrenty 'cause that seems like something someone wouldn't be able to fix to easily...or you could also tape it
two rules to life. its its stuck and it ain't supposed to be WD-40 it, if it ain't stuck and it's supposed to be ducktape it
Posted on May 16, 2009
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Door won't engage and stay closed
Possible that the lock was broken and so the door opened. You can remove the front panel and check for broken plastic or nylon pieces which can be glued using instant adhesive.
Reset the lock and switch and the door must lock in correctly
Jan 21, 2013 | Microwave Ovens
Tailgate won't stay closed
try spraying the latch and mechanism with wd 40, both sides and handle. the bezel where the handle is at just pops out spray the pivot points and the latch cylinders on the sides of gate
Sep 04, 2012 | 1996 Chevrolet Silverado 2500
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
Open Questions:
See all Verizon Communications Samsung Juke Cell Phone - Questions
Verizon Communications Samsung Juke Cell Phone - Red Logo
82 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
