battery not charging , means the charging system is not working , Doesn't mean the battery is bad . The charging system on your vehicle is computer controlled , If the BCM doesn't see the correct voltage , it will raise the idle RPM to over come any load on the system . Probably has DTC'S - diagnostic trouble codes stored in the BCM or PCM , These codes do not always turn on the money light ( check engine ) . Your best bet , take it to the Cadillac dealer , auto zone or any of those has no clue about this . Oh also it will shut down systems .
http://www.esghotwire.com/0213_Pit.pdf
Battery symbo - Charging System Indicators
BATTERY NOT CHARGING - 7Charging System Indicators
The IPC illuminates the BATTERY NOT CHARGING - 7 indicator in the DIC when the PCM detects a malfunction with the generator output. The IPC receives a class 2 message from the PCM requesting illumination.
I work for Cadillac , have for over thirty year's . Have seen people mess this stuff up big time . So do yourself an take to one of my fellow tech's.
Electrical Load Management
The power management function is designed to monitor the vehicle electrical load and determine when the battery is potentially in a high discharge condition. This is accomplished by using a high accuracy battery voltage reading as an indicator of battery discharge rate. The following six levels of load management will execute in the load management control algorithm when there is a high discharge condition:
The first action requests a vehicle idle speed increase to the powertrain control module (PCM) in order to raise alternator output.
The second action requests a greater vehicle idle speed increase to the PCM in order to raise alternator output.
The third action begins to shed vehicle loads in an attempt to remedy the heavy discharge condition.
The fourth action requests another vehicle idle speed increase to the PCM in order to raise further the alternator output.
The fifth action begins to shed further vehicle loads in an attempt to remedy the heavy discharge condition.
If the above five corrective actions fail, the sixth action of power management further sheds loads in a final attempt to remedy the high discharge condition.
Loads subject to reduction include the following:
• The A/C clutch
• The heated mirrors
• The heated seats
• The rear defog
• The HVAC blowers
The power mode master (PMM) calculates the battery temperature, voltage and charging rate at all times while the engine is running. The PMM calculates the battery temperature by factoring in:
