Olivetti 8516 photocopier quality problems
I am having quality problems with the above. The toner is attaching itself to the purple roller and the result is that the photocopy has lines all over it. I clean the purple roller and do the usual required cleans to the patten,etc,etc.
Can you please tell me what part I need to replace to stop this.
After cleaning the purple roller the toner starts to attach after a very few copies .
I face error 261 on olivetti copia 8516
Posted on Sep 19, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Copied paper becomes black
Either your Contrast setting is way too high or you have a faulty machine.
If the machine is a multi-function laser machine with
A) an All-in-one toner cartridge, eg HP or Canon, the problem is probably a faulty Primary Charge Roller or corona wire (rare these days) - or
B) a drum and toner cartridge assembly, eg Brother, the problem is most likely a broken corona wire in the drum.
If either of the above, take the affected part back to your supplier or a remanufacturer in your area. The should be able to confirm the fault and replace or repair.
If the Machine is a purpose built photocopier then either of the above problems may apply but you are unlikely to be able to find it without disassembling the machine somewhat and you should talk to a copier technician.
Apr 11, 2016 | Office Equipment & Supplies
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Xerox M15i uneven print and photocopy quality. Center of the page is darker than edges. I have run the clean drum, put in a new toner cartridge.
If the problem appears BOTH by copy and print situations, the problem is the drum unit itself.
Unfortunately you have to buy a new drum assy.
Sep 04, 2010 | Xerox Office Equipment & Supplies
Printing quality is poor. Color has scratch and dirty. Color distotion
Printing Quality of Printer is Poor due to some reason...
* the toner has low level of ink material...
* some problem in the toner pad,,,
* scratch are due to above two reasons and the problem in Roller of the printer....
Aug 16, 2010 | Lexmark C522n Laser Printer
Gestetner 428 colour photocopier: background effect all over
It's possible it could be the transfer cleaning unit, but it's more likely to be the fuser or the transfer belt itself. If the hot roller is old or dirty or the press roller isn't providing enough tension, all of the toner might not be getting fused to the paper.
If only one color were showing mottling, it would probably be the developer, but it's unlikely that all four developers went bad at the same time.
Jul 03, 2010 | Gestetner Copier
Need Operating Instructions to send with printer.
Hi Marion,
Are you sure about the product code?
Can you just check it once more and confirm it?
The link to the Olivetti Support is,
Olivetti Support
Try to figure out whether your product is matching in their list.
-rate if it helped you
Apr 10, 2010 | Office Equipment & Supplies
I have a Ricoh Aficio 2018 PhotoCopier. Recently it ran out of toner. I reinserted the old cartridge which I had re-filled with toner (ricoh). However the off-side (non-copy side) of the sheets are dirty -...
You probably have a toner spill which has gone under the transfer roller. Open the right side of the machine and you will see a dark colored roller on the inside of the open part. Stydy it very carefully and you will see how to remove the roller including it's holder. be carefull of the springs, they love to escape. also watch as to how the bushings and gears are assembled so you get them back on properly. Clean any toner out from underneath the roller, replace the assembly and run 10 copies of a white piece of paper. this roller runs on the backside of the paper and can cause your problem. Hope this works for you. Check your paper tray as well as toner can migrate down into them.
Dave T
Jul 27, 2008 | Ricoh Aficio 450 Copier
237 people viewed this question
k24674
