Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hook up speakers to 32 inch lcd hdtv
I want to hook up my 32 inch Sharp lcd hdtv with external speakers and control the audio with the remote control. I have not figured out how to do it. Please tell me in detail how to do this. Thank You Ronnie
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
Posted on May 22, 2009
Troubleshooting
using the TV remote access the menu then go to sound settings and turn the speakers back on
Nov 10, 2013 | Sharp LC46LE810UN 46 in. LCD TV
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
How can I connect my altec lansing speakers/bass to my sharp tv? I currently connected it via a wire that feeds from the altec lansing to the tv in the audio input. I am using HDTV and am trying to get...
Probably won't work. The audio amplifier in the TV isn't strong enough to connect external speakers. It would be best to use a sound bar using the optical connection.
Jun 17, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No volume on 52 inch aquos when volume is pushed a picture of a mini plug shows
Check your external speaker jacks for a foreign object that maybe a child could have put in it or if you using external speakers check these for bad connections. The set thinks that you have a jack plugged in so it is either a bad jack, or a bad audio card or something is causing the jack to short itself like a piece of metal in the jack. Also check you audio settings so that you have the tv's speakers selected and not an external jack.
Aug 05, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp 32 inch LCD TV (LC-C3234U)that sits
Try the head phone jack there are some kool remote systems out that support the head phone output.
you can also place them anywhere in the room.
Mar 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to add more Sound, to my Sharp TV , even in the background, when watching movies, sound is very low , think its dew to cable service? Or would just like to Add external Rear Speakers?
The easiest would be installing a surround sound or other sound system that will amplify the audio. Also, some cable boxes actually have a volume control that is only found on the remote, try turning this up.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
Mar 29, 2009 | Vizio L32 32 in. LCD HDTV
How do I hokk up external speakers to the Sharp
I want to hook up external speakers to my new lcd hdtv Sharp and control the audio with my remote.
Mar 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Ldc/hdtv hook-up
Salutations kajeong,
Normally there are not connections on a television to provide "auxillary" speakers to the original unit. Looking at the owners manual for several of the Aquos units it appears that it would have audio outputs, but these normally wouldn't be available for things such as speakers.
Normally the only way to get what your looking for done is by using a separate amplifier and speaker set and controlling the volume for that.
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 11, 2008 | Bose FreeStyle TV Speakers
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
1,126 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
