HP PSC 1210 All-In-One InkJet Printer
Problem for HP PSC 1210 All-In-One InkJet Printer
Ink cartridge error
By sm31061 on Oct 16, 2007
i just put in new ink and the error check ink cartridge light keeps coming on
Solution #1
posted on Oct 16, 2007
Somewhat Helpful)
SparkGap
Rank: Wiz
Rating: 83%, 410 votes
Can you say if you followed the correct procedure to change the cartridge?
The printer does NOT detect the level of ink, it estimates the level from the amount of printing you've done.
If you followed the correct procedure then the level tally will reset.
If you changed the cartridge while the printer was off and moved the carrier by hand then the printer will not know it has a new cart.
Was this helpful?
Yes
No
Solution #2
posted on Oct 29, 2007
Not Rated)
WiseWoman
Rank: Guide
Rating: 81%, 9 votes
Check the date on your ink cartridge.  I bet it has expired.  If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today's date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Comments:
Oct 29, 2007
- Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Was this helpful?
Yes
No
Popular Solutions for HP PSC 1210 All-In-One InkJet
Questions and Unsolved Problems for HP PSC 1210 All-In-One InkJet
Do you recommend HP PSC 1210 All-In-One InkJet Printer?
Answer
Answer
cartridge no. of 1210 printer and it price in combo pack and single black and color
Answer
I changed the black ink cartrige and now when i ask to print it comes up with a dialog box that says... (More)
Answer
I have created a Word document with clip-art in it, but I can't get the clip art to print. Just the... (More)
Answer
installed new cartridges 1210 saying check print cartridges
Answer
the check paper ; check print cartridge lights keep blinking. There is an "E" in the space... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
