Question about Homelite Mighty Lite Lawn Trimmer
Replacing the bump head on homelite string trimmer
How do you replace a bump replacement head on a homelite d630cd string trimmer so it works?? I don't know how to thread the string so it dispenses when bumped.
  • Anonymous May 17, 2009
    cant remove spool head from the trimmer
Undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
Missing the user's manual for Homelite ut20635r trimmer sold by sears
within the bump head (once opened) you will see add arrows, this indicates which direction you add the line, usually opposite to each other, you will have line hold points (4) within the cup. once you have fulled the cup head with line (octupus needed), thread each line through feeder holes and push line into housing making sure you pull line out through the feeder at same time as pushing into head. pold the hell out of everthing or it will go haywire. Vrey difficult, but after about 300 tries at it, you will still go to the dealer to do it. If you can make any heads or tales of my solution..good luck but its how you do it. Regards Russ
Jul 03, 2012 | Homelite Mighty Lite Lawn Trimmer
Need new bump head or full bump and feed unit
You can find some string heads and string head parts for your machine at Home Depot. They have a universal type head and heads made especially for Ryobis and Homelites (I think). Otherwise, several online vendors sell parts for your machine (but you have to pay shipping).
Jul 23, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite Mighty Lite Lawn Trimmer  Logo
1,920 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
