Question about Bosch RS15 1 1/4 Reciprocating Saw
Reciprocating saw only works at certain angles
My reciprocating saw only works in certain positions. if i hold the trigger and rotate the saw it eventually kicks on. it seems like something needs tightened. How can i fix it?
  • 2,176 Answers
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
Posted on May 18, 2009
Makita cordless saws all wont turn off
seperate the handle halves and see if the trigger lock is hanging up. If not replace the switch.
Oct 16, 2014 | Makita 18 Volt Lxt Bjr182 Recip...
Milwawkee sawzall rotated shaft
If this is an older sawzall there is a bushing in the back plate that aligns the spindle. There is a service fixture for proper alignment. If this is a newer one you have a problem also in the gearcase that would need to be looked at. You can go to milwaukeetool.com and with your model number and serial number download a schematic for this tool . Let me know if you need more assistance and if you do I would need the model and serial number also.
Jan 09, 2012 | Milwaukee Tool Milwaukee 10 Amp...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger...
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
May 23, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
Saw seems dead, after 8 - 12 trigger pulls the saws turns on (sometimes) but after you release trigger its dead again???
You should check the brushes and cord first but it sounds like your trigger is shot, not an uncommon failure for this tool. With the cord plugged in, hold the trigger on in one hand and bend the cord around in several placed, especially near the boot and push and pull it in the tool. If it comes on, replace the cord. If the it doesn't react to this, check the brushes. Without knowing which model you have, they should be at least 1/4" long, evenly worn and shiney, not burnt, where they touch the armature. If these check out you need a new switch.
Dec 23, 2010 | Dewalt 10.0 AMP Reciprocating Saw
Changing the position of the blade in the reciprocating saw
blow out all debris in that area w/ comp,air then lube /spray w/ wd-40 real good and work mech, to/fro
Apr 10, 2010 | Dewalt DC385B 18v. Cordless Bare...
Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Mar 18, 2009 | Dewalt Heavy Duty Reciprocating Saw Kit
Cannot rotate the Dewalt 708 mod 3 saw horizontally
If you have loosened the handle a little and pulling the adjustment trigger didn't allow for movement,you may need to remove and clean the turn table.(don't forget,the handle must be loosened for the turn table to rotate)
Please rate this a fixya
Feb 09, 2009 | Cross Dewalt& 12" Double-Bevel Compound...
Comfort features Problem
* An adjustable or rotating blade or handle allows a more natural grip at various angles * A well-balanced design enhances control and tends to make the saw feel lighter * A cushioned grip improves comfort and control, even through long, sweaty jobs * Antivibration features deliver smoother action to reduce fatigue and enhance accuracy
Aug 27, 2008 | Dewalt 9.5 amp reciprocating saw kit
Bosch RS15 1 1/4 Reciprocating Saw Logo
175 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
