Question about Dayton Electric Heater
Face plate came off...not sure how to properly adjust...
Moving in to new apartment and the electric wall mounted heater was on even though the thermostat wheel was to off position. Took off faceplate and now in a mess.
Large central 'disk'...half side is silver and half of the side is painted brown. On the silver side is a hole (so that it can be rotated and a screw accessed at the top that I guess helps hold the item in place). The brown side when viewed with the cover on, shows where the temp is supposed to be...
With the cover off, what is the position that the wheel should be in so I can replace the cover and get an accurate reading...
Inside of the face plate is the following info
Singer Cat No 7169
Says it is a UL listed and has a number that appears to be 8696
Thanks
Brian
    President:
  • 3,433 Answers
This is a landlord issue and should be handle by them. Safety/liability issue Good luck. They will have a heating /AC company repair it.
Posted on Jun 10, 2009
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
99 stratus 2.5 v-6/no spark.will crank over.
CRANKSHAFT POSITION SENSOR - 2.5L
REMOVAL
  1. Remove speed control servo from driver's side strut tower.
  2. Remove crankshaft position sensor retaining bolt Crankshaft Position Sensor
  3. Pull crankshaft position sensor straight up out of the transaxle housing.
  4. (Disconnect crankshaft position sensor electrical connector from the wiring harness connector.
INSTALLATION - ADJUSTABLE All vehicles will be equipped with an adjustable crankshaft position sensor. This can be identified by an elongated mounting hole in the sensor.
NOTE: If the removed sensor is to be reinstalled, clean off the old spacer on the sensor face. A NEW SPACER must be attached to the sensor face before installation. If the sensor is being replaced, confirm that the paper spacer is attached to the face of the new sensor Crankshaft Position Sensor and Spacer
  1. Install sensor in transaxle and push sensor down until contact is made with the drive plate. While holding the sensor in this position, install and tighten the retaining bolt to 12 N·m (105 in. lbs.) torque.
  2. Connect crankshaft position sensor electrical connector to the wiring harness connector.
  3. Attach connector to heater tube bracket.
  4. Install speed control servo. Tighten nuts to 9 N·m (80 in. lbs.) torque.
May 19, 2012 | 1999 Dodge Stratus
Why is our ETS heater streaking the walls and ceiling black?
Electric heaters should not give off anything to make the paint go black , paint will change colour from the heat over time . I would say make sure there is nothing behind the heaters causing this to go black .
Ask where you buy your paint they can advise on paint that will not change with the heat .
Mar 17, 2012 | Heating & Cooling
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
My navigator is like brand new and strong suction, but it just won't move around.
If you are getting suction through the cleaner, but it is not moving around, you probably have wings or shoes improperly installed. If the pool cleaners shoes look worn or are not installed properly, this will happen. A copy of the users manual is below. Check to make sure that they are installed properly.You might also need to adjust the rear tension flap. Finally, even though you think your suction is good, make sure that there are no obstructions or leaks that would cause movement failure.
Apr 06, 2011 | Hayward Navigator Pool Cleaner
Where is the crankshaft sensor on a v6 2000 chrystler sebring
REMOVAL
May 22, 2010 | 1998 Chrysler Sebring
Whirlpool Duet: "remove the heater..."
don't know the whirpool duet cos i'm in uk not us.
i assume your machine is a front loader
places to look for heater are
remove back plate and look for heater at bottom of rear face of tub
sometimes heater is mounted on front plate of tub in which case tilt machine backwards and see if you can see heater mounted towards bottom of front face.
most likely place however is on the rear plate of the tub
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Electric wall mounted heater
Make sure that the heater is mounted where convection currents occur freely. When heat builds up around the top of the heater its temperature will rise uncontrollably. You'll be luck not to get a fire.
Jan 18, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Dayton Electric Heater Logo
118 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
