Furnace Filter recommendation
I have a York Diamond 80 Single Stage upflow furnace. It came with the house but without a manual. The filter that's in there now is the washable type but I've never seen another like it. I just want to get a new disposable media-type filter but don't know what size/type is recomended. Thanks for your help.
  • 116 Answers
Measure the out side to outside most likley 20x20x1 or 20x25x1 depends on the size of unit
Posted on May 16, 2009
Does Malm Day and Night furnace have a filter in the main unit?
Assuming this is a upflow unit? Disconnect power,remove panels should be 2 . Look in blower housing opening bottom of unit where air enters. Units come with filter new.
Oct 16, 2014 | Heating & Cooling
York diamond 80 - continuous flashing red
Is there a chart on it somewhere that describes what each mode of flashing means? Most of them do. Inside the front cover,,,somewhere on the inside of the panel that covers the filter? I've never seen one of these without that diafram.
Oct 24, 2013 | Tools & Hardware - Others
Is there an on-off switch on the furnace?
Generally, if there is not a breaker within line of sight, there will be a toggle single pole switch that will shut the furnace off. The blower cabinet will also have a door switch.
Oct 19, 2013 | Amana AMH95 - 115,000 BTU - Gas-Fired...
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
York diamond 80 fan starts running blowing cold air before furnace ignites..replaced thermostat
OK so you replaced the Thermostat huh? OK well then did you also replace the Thermistor Temperature Sensor? or whatever is used? As often it's BOTH, also check the wiring from the sensor to the host, in any event if it's NOT that then all it can be is the controller board, most likely the Micro? Check any and all sensors first though.. try to get a service manual too, it's hard without one?
Oct 20, 2011 | York Furnace Draft Inducer Blower Fasco #...
How do i change air filter in older york steller furnace
take off the front door if it is a upflow it will be located on the bottm inside of the furnace if downflow it would be in the top
Mar 03, 2011 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
722 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
