Question about Plantronics DSP-500 Headset
Plantronics s11 headset
I can not get my Plantronics S11  headset/amplifier to work correctly. The instructions say to click the headset/handset button to headset, then dial. When the button is switched to headset, I hear a dial tone, but get no reaction when I try to dial the number on the handset.
  I can switch back to handset then dial, then switch to headset and the call will go through. I can hear the person on the other end, but they can not hear me. If I move the configuration button, there is a setting where the other person can hear me but I can't hear them. I have two very old line phones and both react the same. I also have digital cable phone service through Time- Warner. Could the headset be bad? Is there a component in the amp that is known to cause these symptoms?
  I actually bought about 20 of these in a wholesale auction. I would be able to replace and solder a bad component if anyone knows what it is.
4 Suggested Answers
wb91
  • 126 Answers
SOURCE: i connected my S11 plantronics
Most Cisco phones have a headset port where you can connect a headset using a special direct connect cable. This allows you to use your headset without touching the handset (receiver). However, when using an amplifier and headset combination, like the S11, you will need to connect through the HANDSET port. You disconnect the handset cable from the phone, connect the S11 cable into that port and connect the handset cable into the back of the S11 amplifier. Be sure to follow the illustrations on the back of the amplifier when connecting the cables. Also, adjust the configuration slide on the left of the amplifier for the best possible dial tone. Remember that in order to access a call or make a call, you will have to lift the handset off the phone and set it aside (switch hook needs to be activated).
Good Luck from Headsets Direct!
Posted on Jun 03, 2011
wb91
  • 126 Answers
SOURCE: I have the Plantronics S11
There are a couple of basic things to check first. You want to make sure the mute is turned off and your outgoing (mic) volume is loud enough (there is the speak level switch on the side and the speak volume control on top). Also, you want to make sure it is connected through the handset jack on the phone (generally it will not work through the headset jack on the phone). Finally you want to make sure it's configured right (scale located on the side).
Posted on Jul 05, 2011
HDI Headsets
  • 537 Answers
SOURCE: Plantronics S11 head set does not work: hooked up
The Plantronics S11 headset system is meant to plug into the handset jack on your phone not the headset jack. Check the connection on the S11 to make sure the handset jack is where it is plugged into at.
Here are a few suggestions from Plantronics if you are not getting a dial tone:
Make sure all cable connections are correct and firmly in place.
Pay special attention that handset cord is properly connected.
Ensure AC power adapter is connected and power is on.
Make sure you have pressed the headset button and the headset indicator is on.
Make sure the telephone handset is off-hook.
Adjust listen volume control.
Adjust the compatibility slide switch.
Ensure that the headset is centered on your ear.
Good luck from Headsets Direct!
Posted on Nov 10, 2011
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Nov 07, 2011 | Plantronics S11 Headset
When I have the headset plugged in correctly I try to make an outgoing call and my headset beeps extremely loud after ringing once.
Please pay special attention to where the handset cord is plugged in. Then check where the cord is that comes from the S11, it should be plugged into where the handset cord was plugged in. Once that is done check the compatibility slide switch. Adjust the volume on the amplifier. The handset must remain off the of the cradle when making a call.
Jul 06, 2011 | Plantronics S11 Headset
I have tried all configurations settings with my new Plantronics S11 headset, and with some I can hear on the headset, but the caller can't hear me. With others the caller can hear me, but I can't...
You need to remember a couple of things when using amplifiers and headsets. Normally they will not work if you connect them to a phone with cordless accessories. Also, you need to make sure that you're connecting the amplifier to the HANDSET jack on the phone (this requires removing the handset off of the phone to access an open line). Give that a try and you should be fine. If not, contact your retailer or Plantronics at 800-544-4660 x5538 for warranty service.
Jul 02, 2011 | Plantronics S11 Consumer Headset
I connected my S11 plantronics headset to my Cisco 7900 at work and can hear, but callers can't hear me
Jun 03, 2011 | Plantronics S11 Headset
I can hear callers but they can't hear me through the headset. everything is hooked up properly.
Make sure the Plantronics S11 is plugged into the handset jack on your phone and not the headset jack. This will make a difference.
Jan 22, 2011 | Plantronics S11 Headset
There is only one setting on my headset where there isn't a loud tone and the other person can barely hear me. They say it sounds like I am far away. What can I do to fix it?
The Plantronics S11 headset system needs to be plugged into the handset jack on your phone not the headset jack. There is a jack on the back of the S11 system where the curly cord from your handset will plug into. That should fix your problem.
Nov 11, 2010 | Plantronics S11 Headset
I can hear patients and a dial tone if i pick up the phone but noone can hear me
Please pay special attention to where the handset cord is plugged in. Then, check where the cord is that comes from the S11, it should be plugged into where the handset cord was. Once that is done check the compatibility slide switch. Adjust the volume on the amplifier. The handset must remain off the of the cradle when making a call. If the cords are not in the correct place it will not work correctly.
Sep 02, 2010 | Plantronics S11 Headset
Dont know how to hook it up to phone...have S10A and S11 model plantronics corded headsets
Turn over the S11 base and insert the headset slot. This is at the top of the base. Remove the handset cord from your telephone base and plug into the handset jack (there will be a picture). Using the short cord that came with the S11, plug into the line jack on the back of your base and the other end into the slot on your telephone where you removed the handset cord. Plug the headset cord into the headset jack that is on your S11 base. Connect the the A/C power adapter to the S11 A/C jack and a wall outlet. Put on the headset. Press the handset/headset switch and pick up the handset off your telephone, set it aside to make calls. Slide the configuration switch (on the side of the S11 base) until you hear a clear dial tone.
Aug 24, 2010 | Plantronics (45647-04) for S10, T10, T20...
Plantronics S11 head set does not work: hooked up properly, but non of the configuration setting yield tone. At one setting, only after the line goes into fast bipping mode (off hook for a long time) I can...
Aug 06, 2010 | Plantronics S11 Headset
Plantronics DSP-500 Headset Logo
110 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
