Whirlpool S20DRSS33 Side by Side Refrigerator
Problem for Whirlpool S20DRSS33 Side by Side Refrigerator
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
By Yawl on Oct 16, 2007
We have a Whirlpool SD20 RSB33 Side by Side
The freezer side is now periodically malfunctioning; unit 3 years old. The fridge side appears to be working fine. The freezer alarm sounds and when we press the OK button the alarm stops. However the freezer temperature does not return,
When we unplug the unit for an hour or so and then re-connect, the freezer returns to the desired temperature within approximately 15 minutes.
The unit works fine for about 12 -24 hours and then the same thing happens. This cycle has now been going on for a week.
We have checked the seals, verticality of the unit, thoroughly vacuumed the lower sections front and back (first removing the grill covers).
Any suggestions?
Clarification Request
Posted by john-brods on Sep 26, 2009
There is a guy in South Yorkshire who can repair these boards.
john-broderick at hotmail dot com
Same Problem
Oct 27, 2008
-   frbb 2vaf 20
I have just bought a graded Whirlpool Frbb2vaf20 American Fridge freezer & are having problems with the freezer. It doesn't seem to want to freeze. We put it on the fast freeze & it then flashes -- & it then states the temperate & about 1/2 hour later the alarm beeps & it flashes --. it doesn't freeze anything, however it does produce the ice cubes. We have had this problem since we purchased it 2 days ago. -   Mandiz2392
Sep 21, 2008
-   Mine is the S20D RSS33
Same Problem, Freezer alarms sounds. -   benliuk
May 20, 2008
-   Just brought a new freezer off someboby and have found out the fridge/ frezer is about 6 months old. recently the freezer has stopped working with the same problems as the other people, no temperature display and food has defrosted, can you help?-   talman828
Nov 26, 2007
-   S20D RBB32
The display alarmed. It is now acting as first power up waiting to get to temp. No freezer temp displayed just two flashing dashes [ -- ]. The sense sign is sometimes on. It seems to be keeping cold but not as cold as it should be. I'm ore than happy to replace boards etc but need some advice.
I did take off internal panel, defrost etc and it was ok for two weeks or so, but now same problem is back.-   Guest
Nov 26, 2007
-   S20D RBB32
Same problem. I have read it's down to faulty capacitors on the mainboard but I need advice on how to swap these out.
I took off the internal panels, defrosted etc. It was ok for two weeks or so and then the same problem returned.-   Guest
Solution #1
posted on Nov 26, 2007
Not Helpful)
collierm
Rank: Apprentice
Rating: 40%, 1 votes
Apologies, the above two guest comments are mine, not sure what happend!!
Was this helpful?
Yes
No
Popular Solutions for Whirlpool S20DRSS33 Side by
Questions and Unsolved Problems for Whirlpool S20DRSS33 Side by
Do you recommend Whirlpool S20DRSS33 Side by Side Refrigerator?
Answer
Answer
Hello, i Got a Problem with my S2OD RBB32-A/G Whirlpool Ref. its has a Fast and Random Clicking on... (More)
Answer
no more ice, I'm looking for the notice Regards Olivier
Answer
Hi, I have a Whirlpool S20DRSS33 Fridge Frezzer which has been making a chattering noise for a while... (More)
Answer
Regularly the fridge alarm will sound and the letter d appears in the fridge side temperature... (More)
Answer
unit is only 4 years old. paid 160.00 to replace compressor relay.made 2 batches of ice and stopped.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
