Question about HP LaserJet 1100 Printer
I have hp laserjet 1100 printer when i switch it on it is not performing its startup test or self diagnosis test when it starts
...so the "error light" lights right away? Almost surely a fuser error, but regardless, it is not worth fixing when you can replace it for under $100
Posted on May 17, 2009
What shall i do in "scanner error 13" in HP Laserjet Pro MFP M225dn ?
do a power reset to see if that will resolve the issue. With the printer still turned on, disconnect the power cable from the back of the printer. Then disconnect the power cable from the wall outlet. Wait 10 seconds and reconnect the power cable back to the wall outlet first, then the back of the printer and power it on again.
Make sure the printer is connected directly to wall outlet. (don't use a power hub or a surge protector)
Try and print a hardware self test. Disconnect any cables on the back of the printer except the power cable. Follow these steps:
  1. On the printer control panel, press the Setup button.
  2. Use the arrow buttons to select the Reports menu, and then press the OK button.
  3. Use the arrow buttons to select the Config report option, and then press the OK button.
Did the hardware self test print?
Now try and make a copy. Did it copy successfully?
Reconnect any other cables again to the back of the printer.
Now try and do a scan through the software.
Did it scan successfully?
If you are still having issues then please follow the steps below:
  • Go to the Start menu and select run.
  • Type services.msc and click OK.
  • Locate the 'Shell Hardware Detection' in the list. If it is not enabled/started, Make sure to enable/start the service. Also make sure the Startup Type set as Automatically from its properties.
  • Locate the 'Windows Image Acquisition (WIA)' in the list. If it is not enabled/started, Make sure to enable/start the service. Also make sure the Startup Type set as Automatically as well.
  • Locate the 'Remote Procedure Call (RPC)' in the list. If it is not enabled/started. Make sure to enable/start the service. Also make sure the Startup Type set to Automatically.
Dec 05, 2016 | HP LASERJET PRO MFP M225DN
I received error code 52.00 on my HP printer, what does it mean?
Laser scanner start up error.. First of all need to find out which scanner faulty out of two..
Go to menu scroll to diagnosys, scroll to component test, scroll to scanner test....
If the cyan or black component tests showed a startup failure,
reconnect the connectors (J503) on the laser PCA and (J106) and J111) on DC controller PCA... replace the scanner
If the yellow or magenta component tests showed a startup failure, reconnect the connectors (J501) on the laser PCA and (J106)..Replace scanner..
Before starting better to download service manual to better understand the replacement..
Jul 29, 2015 | HP CP3525N Color LaserJet Printer
How to perform self test print on my hp laser jet 2015
all you do to perform your self test is to hold the print button down about 2 seconds
Feb 16, 2011 | HP LaserJet P2015 Printer
Dont have cd printer hp laserjet 1100
If you do not want to order a replacement CD, why not download the printer software for your model from HP: (choose your language and operating system)
HP LaserJet 1100 Downloads
Jan 02, 2010 | HP LaserJet 1100 Printer
Hp business inkjet 1100
Hold the power button for 5~10 secs. Once the green light start flashing, remove your finger to the power button.
Jul 23, 2009 | HP LaserJet 1100 Printer
How do you resolve 59.30 error code on HP color laserjet 5550
finally i solve this problem hp colorlaserjet 5550 error 59.30 same with an error 59.40 ERROR this is occurred with the fuser motor during startup or not rotating. take the left cover off and replace the motor. hope this will help.
Jun 09, 2009 | HP LaserJet 5550 Printer
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
Hp laserjet 1100
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Mar 28, 2008 | HP LaserJet 1100 Printer
HP LaserJet 2430n occasionally prints goblety-gook
ISSUE: When printing from the computer, you receive a line of garbage or all of the printed output comes out on one line. SOLUTION: See the following:
  1. Perform a self-test to be sure that the HP LaserJet printer is functioning properly. If the self-test is not correct, remove all cables and accessories (if any) and print a self-test again. If the self-test is still not correct, service the printer. If the self-test is correct, go to the next step.
  2. Reseat or replace the cable. Check the cable for bends or pressure applied by objects resting on the cable. A faulty cable or cables that do not meet the IEEE-1284 Standard can cause print defects by distorting signals.
Jan 09, 2008 | HP LaserJet 2430n Printer
HP LASERJET 1100 WONT PRINT
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
Aug 14, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
269 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
