Question about Kenwood Audio Players & Recorders
Which jacks to wire the subwoofer to?
Do I wire the subwoofer to the suround jacks?
  • adamjs3 May 16, 2009
    Thanks
    Brigadier General:
  • 8,546 Answers
No.
Since you didn't mention what specific hardware we're dealing with...
usually there's either an amplified channel marked for LFE or Subwoofer that would connect directoly to a subwoofer or there's a single RCA jack for same that would go to the input of an amplified subwoofer.
Posted on May 17, 2009
  • David Dunn
    David Dunn May 17, 2009
    There is no downside to using the connectors as designed and specified. Where did you get that huhu about loss of output power? A Dolby Digital receiver will NOT work correctly unless you use the subwoofer correctly, including configuring the receiver to route the LFE to it if the other speakers are insufficinet in real low bass. It's not about the connections.
  • 32 Answers
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
Posted on May 16, 2009
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
Wires hooked up wrong on back of subwoofer
connect the wires to the corresponding jack for example if one end of the wire is connected to the right speaker same as connect the other end to the same jack in amplifier or player...like wise connect other wires...
Dec 07, 2008 | Durabrand HT-3915 System
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    No sound from suround speakers or subwoofer
    MAKE SURE THE RCA JACKS ARE RUNNING FROM "AUDIO OUT" OF TV TO "AUDIO IN" ON VIDEO 1 ON RECEIVER, THEN YOU SHOULD HAVE SOUND...(IF THIS IS BACKWORDS YOU WON'T HAVE SOUND.) THAT'S HOW OURS IS HOOKED UP AND WORKS PERFECT.
    Sep 08, 2008 | Onkyo HTR500 Receiver
    363 people viewed this question
    Top Kenwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Don Hart
    Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
