Question about Dell Studio 1737 Laptop
THE HEAT SENSOR TOUCH KEYS ON THE DELL 1735 LAPTOP DON'T WORK
The keys r located at the top of the laptop above the keyboard and work by heat sensor touch. there is an eject, forward, back etc. keys, as well as volume control however the << (back) keys is contiuously illuminated and they don't respond. do u have any idea how to fix this problem? thanks
  • 3,940 Answers
The keys on the Hinge cover, have a cable that connects to the motherboard. Reseat the cable and see if any change, if none, then replace the hinge cover assembly.
Posted on May 17, 2009
Brightness screen fn
Many computer users spend long hours online every day and don\'t realize that looking at a bright laptop screen can be hard for the eyes. If you spend a lot of time in front of a laptop screen, consider reducing the brightness of the screen at the earliest opportunity. There\'s a quick and easy way to perform this task so you can save your eyes as well as your battery power.
Press and hold the "Fn" key on the laptop keyboard. T his key is usually located at the top right or bottom left of the keyboard. Press the "Up Arrow" and "Down Arrow" keys, which are usually located in the lower right of the keyboard, to increase or reduce the brightness of your laptop screen. Adjust the level so that you can gaze comfortably at the screen without any glare. Disconnect the battery charger from your laptop and repeat the above procedure. On some laptops, the screen brightness varies considerably, depending on whether or not the device is charged.
Jan 31, 2013 | Dell Inspiron Computers & Internet
My dell 1735 turns on but does not go past the log in. Jumps back to the start up screen.
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/studio-1735
If the F2 and F12 keys don't work, there's something wrong with the hardware. It could be as simple as a faulty keyboard or bad keyboard connection but my guess with the other problems occurring there is something more. You will need to contact Dell for in depth hardware
diagnostic
This could also be the harddrive failing.
Try visit a computer repair shop or a DELL autorized dealer/repair for detailed fault finding.
Good luck
Jan 06, 2013 | Dell STUDIO 1735 Motherboard - H274K
My laptop Dell inspiron N4010 touch pad is not working.. wats the solution
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 11, 2012 | Computers & Internet
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
Cd not coming out..it is running continuously.. button on keyboard not working..! this problem is with studio laptop..no tray provided..!!!!
I just followed the instructions in the manual I downloaded at http://support.dell.com/support/edocs/systems/1735/en/index.htm
It's much more narly than working in a big tower, but the only really tough part for me was lifting up the front panel just above the keyboard--I accidentally disabled the media control buttons. Apart from that it was pretty straight forward--lots of steps, but each simple.
Sep 18, 2010 | Dell Studio 1737 Laptop
Sometimes the keys work and sometimes I have to
take a vacuum cleaner and clean the keys nicely... might be something is stopping it ,,, it still the problem is there u would have to replace it
Jan 12, 2010 | Dell 0Y3740 Keyboard
How do I turn on my backlit keyboard on my dell with windows vista?
Sorry for the last answer. The expert probably didn't understand your question.
If you have purchased the optional backlit keyboard, the right-arrow key will have the backlit keyboard icon on it. The backlit keyboard provides visibility in dark environments by illuminating all symbols on the keys. The settings for this keyboard can be personalized by using
Dell QuickSet.
Backlit Keyboard Brightness Settings – Press <Fn> + right-arrow key to toggle between the three lighting states (in the given order).
The three lighting states are:
a. full keyboard/touch pad brightness
b. half keyboard/touch pad brightness
c. no lighting
Hope this helps. If you need the manual for this computer, it is located here:
http://support.dell.com/support/edocs/systems/studio1737/en/SG/F174HA01MR.pdf
Thanks for using FixYa.
Jul 21, 2009 | Dell Studio 1737 Laptop
Dell Studio 1735 laptop backlit keyboard won't light
how do i take the keyboard out of a studio 1735 by dell plz?
Jun 14, 2009 | Computers & Internet
Dell Studio 17 touch keys do not light up
here is the link for service manual for your laptop...check the cable on center control panel maybe it loose the connection.
http://support.dell.com/support/edocs/systems/1735/en/SM/index.htm
Mar 16, 2009 | Dell Studio 17 Laptop
Dell Studio 1737 Laptop Logo
603 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
