The right front and rear turn signals don't work but the left front and rear signals do work. It is the same with the hazards-the right side of the car doesn't work while the left side works. the flasher relay is clicking when the left signal is truned on but the flasher doesn't click when the right turn signal is on.
Front right and rear right are on a different circuit than the left front an left rear. Locate the Flasher control module behind dash. With key in RUN position check for pulsing battery voltage on the Green/white wire coming out of the flasher control module electrical connector. If no battery voltage, check for battery voltage coming into the flasher from the turn signal switch on the white/red wire. Left turn input is on the white/black wire. If not battery voltage on white/red, but voltage on white/black when turning left, then the turn signal switch is bad
SOURCE: My 97 Miata turn signals
Had a similar problem with my 2000 Miata- had to have the harness inspected and found it was a ground circuit fault
SOURCE: rear left and right turn signal lights not working.
the electronic flasher module may be faulty, or you could have blown a fuse
