Question about Ruud UBHC Air Conditioner
Compresser sounds like its trying to start then it trips the breakers.
Compresser sounds like its trying to come on then it trips the breakers.
  • 116 Answers
Check the capacitor if it is swelled up on top then bad if a amp probe is avable check the amp draw to see if it is locked up should not exceed 25 amps on most at start up hope this helps
Posted on May 16, 2009
Displayed PF, when try to start, trips breaker.
any work done? call them back if so. Hope this is not a new dryer, if so hope it.s under warranty! Sounds like time to look for a lightly used replacement.
Mar 13, 2015 | Dryers
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Engine cranks but will not start checked the connections battery level resisntance in plug wires and coil but but the coil connector is not recieving a constant 12v shows 12v for a second then back to zero...
Pull the spark plug wires off and insert another set of good plugs in them. Do not remove the spark plugs that are in the engine now. You engine has a compression sensor and if it doesn't sense compression it will not have spark. Try to crank the engine will watching the plugs. If you do not see a spark, turn the switch off and listen closely for a slight "tick". I cannot remember what year Harley went to using fuses instead of circuit breakers but you could have a short somewhere tripping the circuit breaker to your ignition circuit. Listen again when you turn the switch back on. After a few seconds, you may hear the slight "ping" of the circuit breaker when it trips.
If that isn't the problem, I'd say that the compression sensor on your engine is bad or you don't have compression. Check the compression on your engine. Good Luck
Apr 12, 2010 | 2001 Harley Davidson FLHTCUI Electra Glide...
Compressure and fan not coming on, contactors pulled in from 24v .light blinks 3 times lps hps are jumped add freon still not working.
Sounds like your breaker is tripping for your outside unit. Compresser could be grounded out or a breaker problem.
Oct 08, 2009 | Haier HC48C1VAR Central Air Conditioner
Error code 61 on remote m#lc340cp
from your description it sounds like this only happened once .. if it happens over and over then there is a different solution ... if the system is shut off then back on right away it will sometimes trip the breaker . this happens often when you have a momentary power failure ... any time the unit is shut off you should wait for a minute before turning it back on .. that allows the internal pressure to drop so the compresser is not trying to start with a full load ..
Aug 20, 2009 | LG Art Cool LA121CNP wall/window Air...
Circuit breaker tripping from the air conditioner
moter or compresser pulling to many amps on start up you can purchase a hard start kit and also you can ohm out blower moter you could also have a direct short althoug not likly
Aug 09, 2009 | Dometic 57915531 Air Conditioner
Air conditionin gunit keeps tripping breaker. A/C is carrier 5 years old compressor?
Sounds like you have a grounded compresser with a direct short.To know for sure you can disconnect the compresser and then flip the breaker and see if it still trips.If it still does check the motor,but this is most likley the compresser sorry.Carrier does have a 5 yr warranty so hurry and call someone it could still be in warranty!
Jul 17, 2009 | Heating & Cooling
Dryer tripped breaker--shotgun blast sound
You may have a wire burn off the element and fall down to the base frame and cause a direct short. Turn you breaker off, remove the front and inspect for such a scenario.
Jun 02, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Ruud UBHC Air Conditioner Logo
59 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
