Question about Brother MFC 420CN All-In-One InkJet Printer
Red and Yellow not Printing at all.
The printer will not print Red or Yellow. 'Cleaning' option from LCD control panel does not help. Print Quality check diagnostic does not print any REd or Yellow squares. I've replaced the Red and Yellow Ink Cartridges, and cleaned the wells they sit in. Brother Diagnostics does not report this as an issue.
  • 832 Answers
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry!  A replacement might costs more than a new mfc 440cn!
Posted on Oct 16, 2007
Steam Jet Clean the print head . Remove your print head. Using the Steam Jet Cleaner (preferably over a trash can to catch the mess!) position the Steam Jet Cleaner nozzle over the inkjet heads and pull the trigger for 1-2 seconds. Steam will jet through the inkjet clearing out stubborn clogs. Of course, colored steam / hot water will fly out the underneath of the print head so be sure not to get in its way. Repeat this process for all inkjets in the print head.
Posted on Apr 03, 2009
How can I get rid of lines on photos
Sir/Madam
Step one: Retry the print
If printing on glossy paper was paused or interrupted in the middle of the print job (for instance, if a cartridge was replaced), the resulting print may show a grainy band. In this case, retry the print and avoid interrupting the job.
Step two: Free up system resources and ensure direct communication
The PC can cause the printer to pause if it is not fast enough to keep the printer fed with data. The following steps can help alleviate this problem.
  1. Make sure that the PC meets the minimum system requirements for this printer.
  2. Restart the PC.
  3. Close out of all programs except for the program the print out will originate from.
  4. Shut down programs running in the Task Bar by right clicking on them and choosing exit. These programs will restart the next time the PC is rebooted.
  5. Ensure that the USB cable is 10 feet in length or less. Make sure the USB cable goes directly from the printer to the PC with no intervening devices in between such as a USB hub.
Step three: Check the paper or specialty printing material
  • Make sure the media is not damaged, scratched, or curled. Always store printing materials in a sealed plastic bag, especially in a humid environment, to help protect the material from damage or curl.
  • HP inks and media are designed to deliver optimum results. Other media may not perform as well.
Step four: Increase the print quality mode
If reprinting did not help and the paper or specialty printing material is not damaged, check the print quality mode:
  1. Open the Printer Properties dialog box.
  2. On the File menu in your software program, click Print .
  3. Make sure your printer is selected.
  4. Click the button that opens the Properties dialog box. Depending on your software program, this button might be called Properties , Options , Printer Setup , or Printer .
  5. Click the Features tab.
  6. In the Print Quality drop down list, choose a higher print quality (for instance, if the print quality is Fast Draft or Normal , switch to Best or Maximum DPI ).
Step five: Clean the printheads using the printer control panel
If you still see streaks or lines in your printouts, clean the printheads using the printer control panel.
NOTE:Always allow the printhead cleaning routine to complete. If the printer loses power in the middle of a cleaning, make sure to repeat the cleaning and allow the printer to complete it.
  1. Press Menu on the printer control panel. Figure 3: Menu button on the printer control panel
  1. Using the arrow keys to move through the menu options, find and select Clean printheads , and then press OK .
  2. Following the directions on the printer screen, load paper so the printer can print a test page after cleaning the printheads. Use plain paper to conserve photo paper.
  3. Press OK to begin cleaning the printheads. A Print Quality Diagnostic page prints at the end of the cleaning. Figure 4: Print Quality Diagnostic page
  1. If there are white lines across any of the color blocks on the Print Quality Diagnostic page, press Cancel to repeat the cleaning.
  2. Cleaning may be repeated a number of times. The number of cleanings (and therefore the length of the procedure and the amount of ink and paper used) will vary depending on the severity of the problem. A Print Quality Diagnostic page is printed after each cleaning. Look for white lines through the blocks after each cleaning, and if the print quality seems to be getting better (fewer white lines), continue to repeat the cleaning. Eventually, a Recommend Six-Minute Cleaningmessage will appear on the printer display. If the print quality has been improving, press OK to perform six-minute cleaning.
    • As soon as the white lines no longer appear in the color blocks, the problem should be solved. Print a normal print job to confirm that the print quality is acceptable.
    • If the print quality is still bad after the six-minute cleaning, or does not improve with repeated cleaning, or is not acceptable even though there are no white lines through the color blocks, go on to the next step.
      Step six: Align and calibrate the printheads
      If you still see streaks or lines in your printouts, align and calibrate the printheads.
      1. Align the printheads:
        1. Load plain, white, unused paper in the main tray.
        2. Press Menu on the printer control panel. Figure 5: Menu button on the printer control panel
    1. Select Calibrate Printer , and then press OK .
    2. Select Align Printheads , and then press OK .
  1. Reset the closed loop calibration:
    2. Select Calibrate printer , and then press OK .
    3. Select Reset closed loop calibration , and then press OK .
    4. The printer LCD will display Ready .
  2. Color calibrate the printer using closed loop calibration.
    1. Load HP Advanced Glossy Photo Paper in the main tray.
NOTE:Only HP Advanced Glossy Photo Paper should be used for this process. If plain paper is detected by the printer, the calibration procedure may fail or print quality may be affected.
    2. Select Calibrate Printer, and then press OK.
    3. Select Closed Loop Calibration, and then press OK.
Step seven: Clean the printheads manually
If you still see streaks or lines in your printouts, clean the printheads manually:
  1. Gather the following items to clean the nozzles on the printheads:
    • Distilled water (tap water might contain contaminants that could damage the printheads)
    • Cotton swabs or other soft, lint-free material that will not stick to the printhead
    • Sheets of paper or paper towels to rest the printheads on
  2. Open the top door of the printer.
  3. Press and hold OK until the printhead assembly moves to the left side of the printer and stops.
  4. Raise the printhead assembly cover.
  5. Remove a printhead and place it on a piece of paper with the ink nozzle plate facing up.
    Figure 6: Removing a printhead
NOTE:Do not touch the ink nozzle plate with your fingers. Touching the ink nozzle plate will result in clogs, ink failure, and bad electrical connections.
NOTE:Do not leave the printhead outside the printer for more than 30 minutes. Ink nozzles exposed to the air longer than this might dry out and cause printing problems.
  1. Lightly moisten a cotton swab with distilled water and squeeze any excess water from the swab by pressing it against a clean plastic or tile surface. Do not use your fingers to squeeze the excess water from the swab, because the oil from your fingers could contaminate the swab.
  2. Gently wipe the nozzles on the printhead with the cotton swab. Figure 7: Wiping the nozzles
  1. Wipe until no ink residue or dust appears on a clean swab.
  2. Insert the printhead in the printer.
  3. Repeat the steps above for each printhead. When all the printheads have been cleaned and reinstalled, close the top door of the printer.
    NOTE:If a message appears on the printer screen directing you to replace a printhead, click the Contact HP link on this page to contact HP support.
Step eight: Replace the printhead
If you still see streaks or lines in your printouts after performing all the steps above, one or more printheads may need to be replaced. If your printheads are still under warranty, click Contact HPon this page to arrange to replace the printheads.
I Hope Your HP Printer Problem Is Solved By Now,In case You still Having HP Printer Problem,Then I suggest You Visit Below URL Link:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00725354
Or
If You still Need assistants Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP PSC 1209 All-in-One InkJet Printer
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Streaks on copy
Try these steps first:
1. Check ink level.
2. Nozzle Check Pattern
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press the <Feed Switch> button to select the appropriate paper source.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Press <OK>.
    The machine prints a nozzle check pattern.
  5. Confirm the pattern is not broken, missing, or a specific color is not printed.
3. Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
You can also try using a higher quality print settings as follows:
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
If the above steps do not solve your problem, it may be a time to purchase a new printhead.
Oct 09, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Have just added new cartridges and only the cyan and yellow is printing. How can I solve this?How do I clean the heads? plus I can't seem to acces the cartridges now that they are in
YOU CAN perform a cleaning cycle by accessing the maintenance option installed on your computers driver.
for windows xp, go to control panel, access printers or printers and faxes, right click once on the icon left click on printing preferences click on the maintenance tab then choose the button for head cleaning and that is it.
do it for 4 to 5 times until all of your prints would be good. print a nozzle check pattern to check the quality
Sep 23, 2009 | Epson Stylus C60 InkJet Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    2. Use the up or down navigation key to select TEST PRINT.
    3. Press Set to confirm your choice.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
Cleaning the Print Head
  2. Use the up or down navigation key to select CLEANING.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
776 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
