Question about Konica Minolta Office Equipment & Supplies
Konica C550 darkening pages
My konica minolta c550 is darkening all pages, what should I do?
  • rod5893 Jun 11, 2009
    No it is not a configuration problem I think, I didn`t explained you very well. Actually that s what is happening:
    I am getting black ink dirty copies with my konica minolta c550. After taking out the black imaging unit I noticed there is black powder acummulating on one side of the imaging unit. I cleaned that, but it keeps acumulating and messing the copies. what should I do?
    Brigadier General:
  • 3,917 Answers
There are 2 reasons for this behavior:
1) If you have made some changes to the settings. The resolution to this is to bring every scan/fax settings back to default; First off, hit the fax/scan key then press the scan setting icon. Make your selections for Original type, file type, resolution etc etc...that you would like to be the default.
While still in the screen, press the Utility key, select #2 User Setting,
select #4 Fax/Scan Settings, select Default Scan/Fax Settings. Highlight the icon that says Current Setting and press ok.
If you are using Account Track or Authentication on the machine, you may have to do this for each account (not 100% sure on that).
You can set your copy defaults, basically, the same way. Just select Copier Settings instead of Fax/Scan in the utility menu.
The second and last reason would be some mal functioning of the toner which is beyond trouble shooting scope and needs replacement.
Thank You
Posted on May 16, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Konica minolta bizhub c550 how to fix ghosting on black
replace the black image unit and run gradation test
Apr 03, 2014 | Konica Minolta Bizhub C550
C-4501 konica minolta bizhub c550
replace the LASER assy. or what is called the printhead
Jan 13, 2014 | Konica Minolta Bizhub C550
I HAVE Konica Minolta Konica Minolta C550 .WHEN I USED COPY OR PRINT EXITING PEAPER IS DIRTY OR HAVE BAR BLACK. PLEASE GUIDE ME
"Dirty" could be one of 3 things... Transfer belt, Imaging unit and fuser unit. Make 5 copies in jam the machine by opening a cover. remove pages and see where the "dirt" originates from.
Jan 08, 2014 | Konica Minolta bizhub Office Equipment &...
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
What is the causes half printouts in black color in konica minolta bizhub c550
write unit block the signal just try to look for the object that block the signal from write unit
Oct 14, 2013 | Konica Minolta Bizhub C550
C5356 at Konica Minolta bizhub C550
Fan! Rear of machine TOP. Middle fan
Feb 26, 2012 | Konica Minolta Bizhub C550
57 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
