Set is from Dec 2006. Worked perfectly until today where I now have vertical lines down the streen (across entire width). The lines are white and blue. In between the vertical lines are white and blue dots (resembles static from the analog days). Extended warranty ended 5 months ago, and now I"m sad....anyone seen this? Thanks!
This sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
ha..thanks for suggestion...oddly enough, tv worked fine the next day and ever since. Maybe I'll luck out some more.
