Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Breaker flipped on my oven while cooking a turkey
The turkey only cooked for 45 minutes.The turkey sat for 1 1/2 hour until i came home. Is it OK to go ahead and cook the turkey?
  • 323 Answers
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
Posted on May 16, 2009
Need to know the cooking time and temp in C in fan forced oven for pork loin roll weighing 1.22kg
usually 40 minutes per 500 grams at 180 degrees C
so 1 and a half hours plus preheat the oven .
And it is thawed not frozen
don't just take my word for it read it on link below
http://www.pork.com.au/home-page-consumer/recipes/cooking-instructions.aspx
Dec 24, 2016 | Ovens
Our SVE47500 or SVE47600 oven has just completely stopped working. The oven was cooking the turkey throughout the night. The timer started going off and even when you cancelled the timer, it still went...
This sounds like you somehow got a little moisture in the controls. With any luck, after it sits for awhile it will dry out and begin working again. Turn your circuit breaker off and let it sit for about an hour to see if you have any luck. It is possible to speed up the drying process by using a hair dryer aimed at your control panel. Use the cold setting on your hair dryer. Repost back here and let me know how you made out. We can trouble further if your unit still does not work.
Nov 25, 2010 | Jenn-Air Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    How best to cook turkey. What setting?
    hi friend,
    step 1
    Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Lost my manual for chef condor integra oven - need to check auto functions and how to set them
    For TOuch Control oven:
    1. Press Finish Time touch pad
    2.press ^ touch pad until clock displays the required am or pm finish time.
    3. Press Cook Period touch pad.
    4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
    5. Press Automatic touch pad.
    Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
    7. Turn oven thermostat to desired setting.
    8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
    10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
    For Multifunction oven:
    1. Set time of day.
    2. Turn Function switch to Finish. 0.00 will be displayed.
    3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
    4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
    5. Turn Function switch to Auto. The automatic programme is now ready to use.
    Turn upper oven thermostat to desired setting.
    If keep warm function is required, turn function switch to Cook (optional)
    Happy cooking!
    Jun 14, 2009 | Ovens
    The inside door on my oven is cracked. What can I do to make the oven usable to cook Turkey?
    If it is only cracked and still otherwise intact (not shattered in bits) you are OK to cook the turkey. Just don't put it in self clean until you replace or have the glass replaced. Brian
    Dec 21, 2008 | Whirlpool RBD305PD Electric Double Oven
    I AM COOKING MY TURKEY AND AN F10CODE COMES UP CAN I CONTINUE OR WHAT
    F10 on Kenmore ovens means Runaway temperature error, it means that the probe sensor detected overheating.
    Stop the oven and allow cooling for one hour or so, with the power cord unplugged.
    If error is still there, then you will need to call the technician and have parts below checked and eventually replaced.
    http://www3.sears.com/imaging/ImageP...&titleID=00003
    Part#316217001
    About the turkey, see if you can borrow one of your neighbour's oven to finish cooking, or leave it half baked and put it back into the oven if the oven restart after cooling up. Remember that you will need to add some more time to the total cooking time, as the turkey will get cold inside.
    Good luckshow?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
    Nov 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Cook timer keeps chiming
    it starts chiming every min AFTER the timer counts down the allotted time?? thats normal operation its remonding you that the timer has completed cookin and to remove food from oven.. it will continue cooking with residual heat if not removed
    Nov 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    128 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
