Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Everything appears to be working, but not internet connection
The satellite modem is connected to the internet (if I plug the ethernet from modem straight to computer I can browse web). The router is connected to the modem via ethernet (wan light comes on at router when I plug in ethernet from modem). Computer says it's connected to wireless network. I can enter D-Link router control panel via 192.168.0.1.
Still can't browse web on computer, even though everything looks connected. Any ideas? Thanks.
  • bobr63 May 16, 2009
    Hmm... Not so sure there is a firewall on either, or how to turn them off.
  • 749 Answers
Turn off the firewall in both the router and the modem. try again-- once it is working ...just turn one of them back on..
Posted on May 16, 2009
  • Jeff Strader
    Jeff Strader May 16, 2009
How to connect Satellite 4090XCDT laptop to ADSL?
You computer was set up to use a modem to access the internet.
You computer does not have USB, so you cannot use Wi-Fi.
You need to purchase a 2 x PC Card Type II or 1 x PC Card Type III Ethernet card. Then you can plug a Ethernet cable into the ADSL router.
Jul 01, 2014 | Toshiba Satellite 4090XCDT Notebook
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
      Connecting directly to a modem:
      3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
    Sep 13, 2010 | Nintendo Wii Console
    Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL...
    I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
    Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
    Jul 24, 2009 | Dell Dimension 4700C PC Desktop
    Computer cabled to Dynex enhanced G wireless will not connect
    Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
    Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
    No internet connection by using the ethernet cable
    Unplug the power to the modem and the USB cable. Plug in Ethernet cable in computer and plug in the modem. Wait for WAN side of the modem to connect and stabilize. If your PC is already on, you should see the network connection appear in the task bar (if it's configured to show up). Open a command prompt. Type 'ping 192.168.1.1' and press Enter. You should get 4 ping responses from the modem which indicates that you LAN connection to the modem is functional.
    Let me know if this doesn't work and I'll guide you through other methods to get it working.
    Apr 09, 2009 | Arris SURFboard SB5120 Modem
    Internet Connection Issues
    Very well could have toasted you network card. If everything else works, try installing a different one (and drivers) that is known to work. MM85
    Jul 26, 2008 | HP Compaq Presario SR1820NX (ER919AA) PC...
    Wrt54g V8 Suddenly stopped working
    hello!
    -- who is your internet service provider
    -- what is the operating system of your computer?
    -- is this working fine before or is this a brand new router
    you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
    Step 1: Shutdown the computer.
    Step 2: reset the router while power on then Unplug the router’s power cable.
    Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
    Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
    Step 5: Plug in the router's power cable once the modem’s lights appear stable.
    Step 6: Power on the computer on and configure the router settings
    Step 7: test the Internet connection.
    if this still didnot work, upgrade the firmware of your router
    May 07, 2008 | Linksys Wireless-G WRT54G Router
    Ethernet vs. usb
    FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
    If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
    Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
    D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
    177 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
