Hi all i have lg lcd monitor L1720B turns on (blue led) after two seconds it goes to power save mode (yellow led) all signal video from pc are ok pleas help!!! thanks ron
    Problem Solver:
  • 4 Answers
Sounds like the monitor expired :((
Posted on May 16, 2009
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
I've got a HP w1907v monitor and latly it has been going into sleep mode without warning while i'm using it. All my power saver settings are set to off.
If this monitor is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 18, 2010 | HP w1907 LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
LCD Flatron 21inch going into power save mode problem
this is not a problem with the monitor, it looks as your computer is not sending any video signals to the monitor thus it goes into saving mode. Take a look at the computer, check the video card. Pull it out then turn it on, turn it off again and place the video card where it should go then turn the PC on again. This should clue the OS to re-configure the video driver. Did you try another monitor ?
Jun 03, 2009 | LG 22" FLATRON LCD Monitor
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
My LCD monitor is going into power saving mode
Hi...there,
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Oct 13, 2008 | Computers & Internet
The monitor doesn't receive the signal from the PC. It is either the PC not booting up or the VGA coard is faulty. Change the VGA coard. or try reseting the VGA cord.
Sep 30, 2008 | LG L1915S 19" LCD Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
