Question about KitchenAid Superba KSRS27CN Side by Side Refrigerator
How do you take the front panel off where the ice dispenser is?
I have this Kitchen Aide refrig and am wanting to know how to get the front of the freezer door apart without damaging the panel?
My water dispenser quit working and I checked the voltage at the watervalve from the water dispenser and did not get 120 volts when the arm was pushed. So I need to check the switch.
  • 1 more comment
  • msf4761 May 16, 2009
    I just want to get the panel off where the ice and water controls are so I can check the switch to the water dispenser.
    I am only interested in getting the ice and water dispenser panel off thr freezer door
  • msf4761 May 19, 2009
    no thanks i have figured it out myself
  • 355 Answers
Check ths guide...hope help you
http://www.appliance-repair-it.com/ice-dispenser.html
and for door gasket check this
http://www.applianceaid.com/frig-doors.html#gasket
Posted on May 19, 2009
    Sergeant:
  • 296 Answers
Push colored rings toward white collar while pulling hose from coupling
Posted on May 18, 2009
  • 952 Answers
Try to open the fridge door.. usually. you can find screws underneath the rubber seal (the rubber part with all the magnets). I have checked my fridge and found screws underneath the rubber seal. well, hopefully your fridge door was not assembled using rivets. I hope you get your fridge fixed. Have a great day sir.
Posted on May 16, 2009
    Brigadier General:
  • 3,917 Answers
Please find the steps of removing the freezer door:
Pull the refrigerator away from the wall. Unplug the power cord. Look above the freezer door on the top of the refrigerator. Remove the two metal hinge screws from the freezer door on the hinged side of the door.
  • Step 2 Unscrew the hinge at the top of the refrigerator door. Install it in the same place at the other side of the door. You are just switching the hinges to hang the door on the other side. Look for the holes that are already there for this purpose. Remove the top hinge plate.
  • Step 3 Re-install the two screws in the holes on the top of the fridge. Look on the top outer edge of the handle side of the door to find a small plug. Use a screwdriver to pry it out. Place it in the hole where the original hinge plate was removed. Lift the freezer door off the base and set it aside.
  • Step 4How do you take the front panel off where the ice  - 96448_thumb.jpg Look on the bottom of the fridge door on the hinge side for the bracket with the two screws in the fridge frame. It will be the same color as the fridge. Remove the two screws, causing the fridge door to drop. Place the door to the side. It may be easier to have a second person in this step to catch the fridge. Replace the two screws in the fridge frame.
  • Step 5 Remove the center hinge bracket with the screwdriver (set between the fridge and freezer door). Put the screws back into the frame. Remove the two screws from the frame on the handle side of the fridge. Remove the first screw from the outer edge between the fridge and freezer.
  • Step 6 Flip the originally removed center bracket upside down. Attach it with the removed screws. On the bottom fridge door, pry out the pivot pin. Remove the small screw from the bracket. Attach the pivot pin bracket and pin back onto the opposite side of the door.
  • Step 7 On the old hinge side of the door, find the small plug on the face of the fridge door. Pry it out. You will see another plate or plug in the same area. Pry this out as well with a screwdriver and remove the screw under it. Remove the two screws on top of the fridge door that support the handle. Remove the handle and replace the screws. Replace the handle on the opposite side.
  • Step 8 Remove the two screws on the bottom fridge frame, and remount the fridge door. Remove the screws from the top and bottom of the freezer door handle and remount on opposite side. Remove the pivot pin plate from the old hinge side of the freezer door and re-attach the freezer door handle on the new side.
  • Step 9 Remove the two screws from the top of the fridge on the old handle side. Place the freezer door back on the center pivot. Re-mount the top hinge bracket.
    Thank You
  • Posted on May 16, 2009
    My kitchen aide ice maker is making ice but not dispensing the ice
    Check that the ice auger is turning freely and not jammed.
    Jul 19, 2017 | Refrigerators
    Ice maker not working, no water or ice dispensed.
    Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
    Oct 13, 2009 | Westinghouse Refrigerators
    Superba kitchen aide refrig red light for water filter wont go of
    You just need to replace the light switch on the filter control panel. I hope this helps you out.
    Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Flashing red light on ice maker control
    Hi
    I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
    Thanks
    Jul 16, 2009 | Whirlpool Refrigerators
    Ice dispenser paddle hard to push
    I know it's been a whle, but I recently had hensame problem. Unable to find an answer I decided to pull it apart. After removing the water/ice dispenser panel I noticed there was a spring loaded rod which held the ice flap in position. The rod had worked itself loose from one end and was causing the problem. I realigned the rod with the hole in the bracket and gently tapped it back into place. After re installing the panel everything was back to normal. You can find some decent tear down videos on Youtube explaining the panel removal. Hope this helps if anyone else runs into this problem. http://m.youtube.com/#/watch?v=0Tmpt63T79M&desktop_uri=%2Fwatch%3Fv%3D0Tmpt63T79M
    Jan 08, 2009 | Quantum (45650101) Quantum Juice Dispenser...
    Kitchen refrig will not dispense ice or water
    IF anything went bad it would be the water valve but is shouldnt have failed just because you didnt turn the water on.Just for grins, unplug the wires to teh water valve and plug them back in to make sure you have a good connection.Then unplug the fridge for a minute and make sure the water is on , and plug the fridge back in.Your solenoid may be stuck.THese are just things I would try..I'm mechanically inclined but am not a appliance repairman.
    Dec 22, 2008 | KitchenAid KSRS25IL Side by Side...
    REfrig
    whats the model number?????
    Jun 02, 2008 | Refrigerators
    Kitchen Aid Superba refrigerator
    turn water valve off behind frig thie will of course turn off ice maker, but will solve water mes problem then work on source
    Jan 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
    Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
    valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
    Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    KitchenAid Superba KSRS27CN Side by Side Refrigerator Logo
    346 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    mike cooper
    Todd Arndt
    Todd Arndt
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
