Question about Asrock K8 Combo-Z Motherboard
Where can I get support CD for K8 Combo Z? - Asrock K8 Combo-Z Motherboard
    President:
  • 987 Answers
Gripper picks up cd, places it on turntable, returns it unplayed and keeps repeating same function
No it is an optical illision. You need to undo the whole bracket with K8 o it and move it aside slightly, to get to the lever on the end of the rod. Remove that lever on the rod and the bracket for K7 slides off.
Jul 08, 2012 | Wurlitzer Jukebox 1015 One More Time...
I cannot boot the system,no display,no functions at all any help/ I bought the empty case with only the motherboard and the cpu, I then add all the other periphirals but could not get it to boot as I am...
You please check on the motherboard bios jumper is set to normal or not - you can see this jumper a three legged with two pins closed near to the cmos battery
Nov 19, 2009 | Asrock K8 Combo-Z Motherboard
ASROCK K8 Combo Z When I turn on there is no POST no beeps. Fans om Mobo and on graphics card spin but nothing else happens. I can not even turn off using the computer on switch I have to turn on at the...
Hi c_j_quinn,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Mark
Nov 06, 2009 | Asrock K8 Combo-Z Motherboard
Need an onboard ethernet driver
You can download the required drivers from:
http://www.asrock.com/mb/download.asp?Model=K8%20Combo-Z&s=754/939
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Sep 03, 2009 | Asrock K8 Combo-Z Motherboard
USB Power Issue with ASRock K8 Combo m/b
Are you plugging in to the usb ports on the MB, or on the case?
Jan 14, 2008 | Asrock K8 Combo-Z Motherboard
Dead Mobo?
Do you have both power connectors from the PSU hooked up?
You need both the large one near the ram, and the smaller square 4-pin one near the printer port
Nov 22, 2007 | FIC K8-800T Motherboard
New Install
replace your data cables and retry. else check your jumper settings to set as slave on the cdrw and master on the hdd.
Sep 17, 2007 | Asrock K8 Combo-Z Motherboard
Can't install Hard Drive MS Server 2003
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Aug 16, 2007 | Asrock K8 Combo-Z Motherboard
Asrock K8 Combo-Z Motherboard Logo
74 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
