Question about SanDisk Sansa Clip MP3 Player
I lost my manual for iHome Model iH27B
Can't figure out how to set the clock
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
How do I Set time on ihome HPL10
This is a hotel version of the iHome iPL10 which has the Set Clock button on top. Instead, the set/sync button is on the back of the unit. This is typically covered by a plastic cover to keep guests from messing with the time settings on the clock. The covered buttons allow you to set Volume Limit: high or low, Time: set/sync, and Day Light Savings Time (dst) +1 -1 or Auto.
Since this is the hotel version, there is no User Manual on iHome's web site.
Jun 13, 2014 | Pioneer DXT-2266UB Car Audio System
Lost manual and can't figure out how to set time on GE alarm clock model 7-4894A
You can download copy of the user manual for this device from this link , just click HERE and you can follow the steps there on how to set the time on it and make sure to save a copy of the manual for future use.
Jun 18, 2011 | GE 7-4894 Clock Radio
How do I program my remote for the ihome ... I lost the manual and I cant find it.
According to the manual the iHome IP90 line does not have a programmable remote. Have you checked the battery in the remote? It requires a CR2025 battery. The remote also has a 30ft. range, not sure if you are trying it at a further distance.
In any case, first thing I would do is to get a replacement CR2025 battery and give that a shot. If that doesn't work then the remote might be defective.
May 06, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
I have the jwin jl cd 809 model and i lost my manual and im having a hard time figuring out how to set the present time and how to set the alarms time
Mantain pressed the CLOCK-ADJ button and turn de big silver knob to the left for setting the hour or the right for setting minutes. Then release the CLOCK-ADJ button.
Sep 22, 2010 | Jwin JL-CD809 Clock Radio
I would like an instruction manual for a Brookstone Tranquil Moments Bedside Clock Radio model #406876
Can I get an instruction manual without paying $12? That is all I want, but that is too much to pay.
Jul 22, 2009 | Brookstone iHome Alarm Clock Radio Remote...
Timex Clock Radio 308
www.timexaudio.com Select Support/Product Manuals from the menu and select your model from the list to get a .pdf version of the manual.
Jul 14, 2008 | Audio Players & Recorders
SanDisk Sansa Clip MP3 Player Logo
576 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
