Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Have a 20 HP twin cylinder briggs engine on Yard Machine mower.
I was just mowing along and it started losing power and popping. I shut it off for a few minutes to let it cool off and it will restart with no problems, it's still not running right and making an occassional popping sound. I have since installed new spark plugs,still same problem. Sometimes it seems as if it is running on one cylinder. My next thinking is that it is probably the ignition coil. Was wondering if anyone else has had this problem ? Any ideas/help will be greatly appreciated because the grass here in KY is growing so fast with all this rain, you can almost hear it growing, Thanks in advance
  • 143 Answers
Sounds like it might be the air breather filter, remove it and see if it works
Posted on May 16, 2009
  • 389 Answers
You can purchase an ignition tester, the kind with the light inside it and check each cylinder at the spark plug to see if the coils are both firing steady. Look at your plugs and if one is nice and clean looking and the other is black and sooty or wet that will be the bad cylinder.
Don't know for sure but this may be something to look at. Remove your valve covers and check your valve clearances at 10 degrees past TDC compression stroke on each cylinder. They should all be .004 to .006. If you have one that is really far out of adjustment, it will most likely be an exhaust valve seat has popped loose in the head. Pull that head and look at it. If they are all pretty close to being set correctly, you may need to do a valve job on both heads due to excessive carbon build up
Posted on Sep 21, 2009
I have the same problem. Worked on in several times and have figured out it is definately misfiring on the right side cylinder. The sprak plug on that side has a darker color than normal, replaced with new one several times - problem still exists. Thought it was a valve problem, possibly exhaust valve. Got a feeler gauge and both cylinders are good and measured the same - got spec from briggs book. I then thought it was a coil prob, got a new coil - still have prob. Mower shop said to check the carb. I removed it, tore it apart, didn't notice anything, but cleaned it thouroghly, reassembled - still have same prob. My thoughts keep goin back to valve prob, so I got a compression gauge. Removed plugs and fuel, attached gauge, turned the starter several times per instructions - got about 60 psi on both cylinders. So now I'm frustrated, not sure what to check next. HELP!
Posted on Sep 16, 2009
I have a briggs and Stratton 22 hp Intek V-twin engine on our Craftsman riding mower. After about 30 minutes of mowing the engine suddenly began to run rough, loud and out of sync.
my thought is the valves are out of adjustment. that is the popping you hear or backfiring. i think if you take off and clean the carburetor and set the valve lash it will probably run like a new one.
May 17, 2016 | Garden
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Jun 24, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
874 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
