Question about Sony Walkman NWZ-B135 MP3 Player
At device manager I receive this message. Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) I have updated driver and it says "The best driver software for your device alresdy installed" So is the pronlem on my pc or my mp3 player. Thank You.
    President:
  • 1,285 Answers
If you have windows 98/nt or xp (vista will detect the device) uninstall the device software from the pc
(control panal /add remove program) and /or from registry (start/run/type regedit/look for hkey current userr/software/sonyxxx). reboot now reinstall the sony software. you should now be connected and see all the files on the mp3
Posted on May 16, 2009
My PC is not recognizing my camera, so i cannot download my pictures. It used to work fine for 2 years. In the Device Manager it gives me the following message: Windows cannot start this hardware device...
Windows updates has changed the registry and now your camera is no longer recognized. No problem....just get a card reader and use it instead of your camera for downloads.
Oct 13, 2010 | Canon PowerShot A570 IS Digital Camera
Microsoft WPD FileSystem Volume Driver message Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Hello.
It seems you have a faulty driver.
Recommended resolutions
A registry problem was detected.
This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
Method 1. Uninstall and reinstall the driver
Uninstall the driver from Device Manager and scan for new hardware to install the driver again. Here is how: First, please disconnect all USB devices and then perform the following steps:
1. Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall . Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action , and then click Scan for hardware changes . Follow the instructions.
Method 2. Revert to the most recent successful registry configuration This content is designed for an advanced computer user.
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
With regards FIXYA team **Please post your feedback and Vote if the problem resolved as per your satisfaction**
Sep 27, 2010 | Sony VAIO VGN-SZ440 Notebook
Code 19 DVD DX not working
  • Open up your Device Manager where you'll see your DVD DX Hardware Device that no longer works correctly. Click it, and then click uninstall. Once uninstalled you can reboot, or click 'scan for new hardware'. Either way Windows will find your Device again and reinstall the driver and probably fix the registry entries.
  • If that does not work, reboot your computer holding down F8 and select 'Load Last Known Good Configuration' before booting into Windows again. It'll restore your settings back when it didn't detect any problems.
Apr 21, 2010 | Computers & Internet
I have HP Pavilion 9500,Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Code 19 Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19) Recommended resolutions
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 (http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP Edit the registry
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP
hope this helps
please leave feedback
thanks
Robb
DVD-RW does not work and is not recognized. It does show up in device manager but the device status lists the following error: Windows cannot start this hardware device because its configuration...
Download and run a registry scan with ccleaner from here.
http://www.filehippo.com/download_ccleaner/
This will remove the corrupt registry entries. You will need to restart your PC afterwards and may get the "new hardware installed" message.
Dec 23, 2009 | Toshiba Satellite A215-S4747 Notebook
As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site: http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true (http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/default.mspx?mfr=true) The registry information applies to Windows XP.
Good Luck .. !!
Nov 22, 2009 | Acer Aspire 5315 Notebook
Code 19 error on ibm windows XP PC...neither the DVD or Cd drive are recognized or able to perform any functions.
Aug 20, 2009 | Office Equipment & Supplies
try to uninstall the cd rom.... then restart your computer
Jun 29, 2009 | Sony DDU1642/C1 Internal DVD Drive
Sony Walkman NWZ-B135  MP3 Player Logo
273 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
