I bought Steren RCA - RG6 jacks (P/N 200-085) and need to know the proper way to install them on RG6 cable. Do you fold the braid back over the jacket when installing? Is there documentation that descibes the length of exposed center conductor. Thanks, Don
  • ldh_don May 17, 2009
    Thanks for the info BB. And yes, I have all the tools, but I didn't have the info as to correct install. I appreciate your time and help with my problem. Don
  • 32 Answers
Don,
Here is a link to the manual for the connectors you bought: http://www.sterenusa.com/bssd/news/NPR_PDF/PermaSeal.pdf
If you don't have one already, you will need to get a compression tool for these connectors. They range in cost from about $25.00 to $50.00 US. Also, If you aren't experienced with stripping coax cable you should probably buy the stripper they recommend for these connectors.
As for the braid, don't fold it back and usually the center conductor should be cut to about 1/4 inch on connectors like these.
Good Luck,
BB
Posted on May 17, 2009
My samsung tv produces sound but no picture on digital tuning - what do i do
Check to see if it's on the correct input. You need to match the input with the cable type you used. HDMI, RG6 cable, RCA jacks, Etc...
Aug 17, 2014 | Televison & Video
What kind of cable to run for HD update?
I ran regular RG6 through my house and both DirecTV and Comcast work just fine. Longest run I have from source to box is about 50' if that factors into your planning.
May 20, 2014 | RCA 12' Quad Shield RG6 Coax Cable...
Trying to plug my ilo up with cable the cable plug does not fit eail i
a standard rg6 coax connector push or screw on type will work. also a s- video cable will work. don't forget to run your rca audio jack with the s video. make sure you turn the correct input on your tv.
Jan 10, 2010 | iLO 2600 Television
RCA DCM425. What coaxial cable do I use? The RG6
Contact your cable provider, you most likely have a signal issue related to poorly seated fittings, outdated or wrong bandwidth splitters, or low signal from outside feed. Quadshield rg6 is the best indoor residential application though. -Comcast tech
Oct 18, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Prong on RCA antenna cable too large for spot on Toshiba vcr/dvd
Hi, You need to look on the cable itself to see if it is an RG58 or RG59 or RG6 or RG9. On an RG6 cable the center conductor is larger than on an RG58, The RG6 cable is used for incoming cable, satellite ect. An outside antenna is not usually equipped with an RG6 unless it is of the new HD variety, which is meant to go to one of the newer tvs. You can remedy the problem a couple of ways, use the ant out on the tv if you have one or use an adapter that fits 2 coax cables together and use a RG 58 jumper from the adapter to the vcr. Good Luck!
Feb 15, 2009 | Toshiba Televison & Video
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Locating a coaxial cable to replace factory supplied cable
Radio shack should have what you need. RG6 is better than RG59 if you have a choice.
Jul 28, 2008 | RCA DRC8335
139 people viewed this question
 Grubhead
Grubhead
