The burners on the stove top with not ignite.
Will have to ask some basic questions first. How old is the stove? What is the entire model # from the sticker on the unit? Is this LP or natural gas? Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean). Make sure that the black caps are on top of the burners and seated properly or they will not lite. Let me know what you find.
-F1- ERR
(Lock)
constant beeping....
came home from being gone this weekend to this situation and can not find the manual HELP !!!!!!!
SOURCE: Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Testimonial: "Thank you!! "
SOURCE: none of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
The top Right rear burner will not light even after cleaning the little hole. I can see that it does not spark. If I need a new igniter, then how do I change it?? So in other words, how do I get the top off to gain access to it?
whirlpool accubake electric stove. Burners are shut off but red burner light stays on
igniters on stove top all start igniting with stove off
how to fix a Kenmore Elite 30'' Gas Cooktop it ignites but hard to light up
burners have to be mmanually lit
need to get underneath burners
